It is currently Mon May 12, 2025 12:48 am
PostPosted: Fri Oct 18, 2013 10:45 am
It might, I don't know. I learned about the properties of EZ Turn by reading the military specification for it. Maybe you can find one for the product in your link. Or at that price, maybe get some, put it in gasoline for a couple days, and see if it dissolves.
PostPosted: Fri Oct 18, 2013 11:39 am
Peter 750 wrote:
two-stroke-brit wrote:
Ivan recommends lapping the bowls flat again and it cured my incontinent bowls.
to make it easier is to use a plate with a 1 1/4" hole in it with some 400 wet n dry paper stuck to it.
i got OEM gaskets from Ivan as well. :thumbup:
I'm sorry, but can you explain more if you will?
I'm having the same leaking problems with my '73 H2A....!
I've used sealer to stop them from leaking, but if there's a better way...??
here is a link to a thread i made showing what i did
viewtopic.php?f=14&t=5186
hope this helps mark
PostPosted: Fri Oct 18, 2013 12:01 pm
Thanks, the pictures explain a lot to me..!!
Are they leaktight now...??
1973 Kawasaki 750 H2A,
1969 Garelli Rekord 50cc,
1985 Ducati Mille MHR.
PostPosted: Fri Oct 18, 2013 1:13 pm
Thanks "brit". I hit the link and read the other post, brilliant. I forgot about the overflow tube. Looks to be the same method as the petcock fix with no fine sanding required. I guess the two gasket method could regain any depth or capacity lost in sanding down the bowl gasket surface! (to those worried about thousandth's) EZ Lube on the way, but I'd still like a referral for a gasket retailer or Ivan's link.............Please. I'm just trying to find gaskets with the proper fit. I have two new sets that certainly don't.
PostPosted: Fri Oct 18, 2013 1:23 pm
peter yes no leaks now . i have pm you
and Ivan is a member here just do a member search and you will find him.
Last edited by two-stroke-brit on Fri Oct 18, 2013 1:26 pm, edited 1 time in total.
PostPosted: Fri Oct 18, 2013 1:25 pm
Just keep in mind that EZ-Turn is not soluble in gasoline, so if a glob gets free and into the fuel, it will clog jets, etc.. Use it carefully and sparingly. You can clean it off things with rubbing alcohol, even though it resists gasoline with alcohol in it.
PostPosted: Fri Oct 18, 2013 7:19 pm
http://www.ivansperformanceproducts.com/ :wave:
PostPosted: Sun Oct 20, 2013 4:35 am
http://www.aircraftspruce.com/catalog/cspages/ezturnlube.php?clickkey=5414
There may be a supplier closer to you, I don't know.
To bad, can't find it on Ebay... :-?
PostPosted: Sun Oct 20, 2013 11:10 am
New Product maybe? :lol: :lol: :lol:
"Lakeland Lube", for when you're leakin gas......
