It is currently Tue May 13, 2025 12:23 am
 Post subject: Help
PostPosted: Sun Aug 25, 2013 10:35 am
Hi all.
Fitted my clip ons today but had a disaster at the end....
Left one plug disconnected and started her up. Realised when she ran like a dog.
Connected it up but now I have no lights or indicators? Really puzzled!
Fuse is fine.
Any thoughts?
Cheers.
It's a kawasaki kh125 1990. 6v system.
Cheers, Robster.
 Post subject: Re: Help
PostPosted: Sun Aug 25, 2013 10:55 am
Check the wiring in the headlight.
PostPosted: Sun Aug 25, 2013 11:09 am
Done that. Can't see anything unless I'm just blind from looking at it all for so long.
Would anything have fried with me leaving one thing unplugged?
Cheers, Robster.
PostPosted: Sun Aug 25, 2013 1:09 pm
earth trouble connect a wire from the lights controls to the frame just to sse if you have lights after.
PostPosted: Sun Aug 25, 2013 3:10 pm
Had a play. Can't see why it's not working. Horn isn't working either now.
However the front and back light come on when you use the parking light?
Cheers, Robster.
PostPosted: Sun Aug 25, 2013 3:21 pm
Leaving off a plug wire wouldn't have caused this. As Husson73 said ^ it sure sounds like a ground wire broke/disconnected/came unplugged. That's normally the cause of whacky electrical problems like you're describing.
Since this happened immediately after your handlebar change, try to find what ground connection was disrupted because of that work.
PostPosted: Mon Aug 26, 2013 2:48 am
Thanks a lot!!
Was considering disassembling it all and going again.
Really odd because it worked briefly then went.
Appreciate the advice all!!
Cheers, Robster.
PostPosted: Mon Aug 26, 2013 2:55 am
As a thought...
Would any earth be ok being on the fork as apose to being on the top yolk where they were previously on the bar?
I hate electrics. Haha
Cheers, Robster.
PostPosted: Thu Aug 29, 2013 8:09 am
Just pulled it all apart again. Unplugged everything and made real sure it's all in properly.
Still no luck.
I wonder if I have pulled a wire out of the rev counter unit or the ignition?
Is that possible?
Are they easy to open up?
Cheers.
There are 2 earths in the headlight unit for the indicators but can't see any others?
How would I check its all earthed?
Cheers, Robster.
PostPosted: Thu Aug 29, 2013 8:20 am
If something like an indicator bulb for example, is connected properly, when it's lit, one terminal will have about 12V on it, and the other will have nearly zero volts on it. If the ground side is not connected to ground, it will also have about 12V on it, and it the bulb won't be lit.
