It is currently Sun May 18, 2025 3:17 am
PostPosted: Sat Aug 02, 2014 12:42 pm
To All
I just spent 2 hours wire brushing and gunking these cases.......should have seen them before :shock: ........obviously they are going to need something a bit more industrial strength..........what is the best method to get these prepped :?: .........have them hot tanked ? or can that warp them.........or have them bead blasted and what about the steel bearing bosses ?......then run a die over the studs (may have to replace one)
They also have one pushed in pin on the needle bearing of the trans input shaft.......how do you get those out ?
THX for your advice in advance :!: Phil
PostPosted: Sat Aug 02, 2014 12:53 pm
Bead or vapor blast cases... Avoid bearing surfaces.
Drill behind pin and push it up http://www.kawasaki.org.uk/saved/pins/
PostPosted: Sat Aug 02, 2014 2:52 pm
Thank You Dale as always........and for keeping the triple library of congress running :!:
THX Phil
PostPosted: Sun Aug 03, 2014 6:57 pm
Looks like Tim Steele may be the guy to get them to.......his blasting stuff looks really good :!:
I will PM him soon
THX Phil
PostPosted: Sun Aug 03, 2014 11:10 pm
I will be happy to do them for you.
PostPosted: Sun Aug 03, 2014 11:17 pm
Tim can probably retrieve that pin for you as well.
John in Wisconsin does vapor blasting I believe.
johnatkens is his user name.
PostPosted: Mon Aug 04, 2014 10:10 am
Hey Tim.......Sounds good, well get in touch (give you a hollar as we say in these parts) :lol: when I get everything rounded up
III I looked at some of the vapor blasting.......some guy in PA arnolddesigns.com "Vapor"......has some neat looking H2 stuff on his site, I think he requires it bead blasted first though.......Tim stuff looked good enough I would think ;) .......hope you are doing well and it was good to meet you at Mid-Ohio :!:
THX Phil
PostPosted: Mon Aug 04, 2014 1:22 pm
Great meeting you as well Phil.
Tim is a great guy to deal with.
Go for it man.
