It is currently Thu May 01, 2025 3:35 am
 Post subject: 69 H1
PostPosted: Sun Jun 29, 2014 11:05 am
Just took in another project, cylinders have never been off. Spent 6 hours yesterday and they are not budging. Used lots of heat, a pusher and
PB Blaster. Will give it another go next weekend. Pistons move but cylinders are corroded on the studs :(
 Post subject: Re: 69 H1
PostPosted: Sun Jun 29, 2014 1:07 pm
Looks like a challenge to me. ;)
PostPosted: Sun Jun 29, 2014 1:11 pm
Nothing unusual there, A bit of anti-seize on the bottom area of the studs will stop that, of course if you ever get the cylinders off....... :banghead
PostPosted: Sun Jun 29, 2014 7:54 pm
Standard bore bridgeports but they don't want to budge. :eh:
PostPosted: Sun Jun 29, 2014 8:03 pm
Time for the MC hammer...used with judicious force, of course. :D
PostPosted: Mon Jun 30, 2014 9:43 pm
Ron, you have any cases left in the garage for an early H1 ? looking for KAE 00560 to 00650 range
PostPosted: Mon Jun 30, 2014 9:48 pm
Sorry I sold my last set to a member here from Norway last December. Only set I have on the shelf is a 74 set with rubber mounts going
into my next build for myself.
PostPosted: Mon Jun 30, 2014 10:09 pm
Just thought i would ask, if you hear around town on the west coast of any early cases floating around send them my way :thumbup: . thanks
PostPosted: Mon Jun 30, 2014 10:53 pm
The rig you have looks good - I would try muriatic acid down the stud holes or even hydrochloric acid..just a spoonful and have lots of water nearby to neutralize before it hurts the aluminum.
PostPosted: Mon Jun 30, 2014 11:22 pm
That sound like a good plan. I'm letting them soak with PB blaster till the weekend. Will try again Saturday, should have some acid on the shelf. :thumbup:
