It is currently Wed Apr 30, 2025 12:05 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: 1974 III H1 500
PostPosted: Wed Aug 21, 2024 7:03 pm
And more pictures.
PostPosted: Mon Aug 26, 2024 5:51 am
I'm hoping I have the wiring harness routed properly here's where I have it roughly routed now.
PostPosted: Mon Aug 26, 2024 5:58 am
I've been doing a lot of research on this project. Never worked on one and didn't take it apart. So it's been challenging. But It's starting to get a lot clearer.
I removed the center stand to make room for the chambers. I'm considering selling that. Got the rear brake linkage attached along with both foot pegs.
Same thing on the left side foot pegs and laying out the sift linkage.
JBoz did a outstanding job on the seat. I thought I was going to have to buy rubber dampers etc.. Nope !
PostPosted: Mon Aug 26, 2024 9:56 am
John is defiantly the powder coat king. Awesome look with the stainless steel allen bolts. Thank you John! I'm going to use my Dremal tool and work on the Kawasaki logos, I think it needs shine there. I'm not sure if I will do just the letters or the back ground surrounding the letters.
PostPosted: Mon Aug 26, 2024 9:58 am
I'm also thinking slightly different colors on the fender and head light brackets. My thought is going dark. The reason being the cases are powder coated black vs polished aluminum. The expansion chambers I ordered originally were suppose to be clear coated. Well although the site said they were available, all he had were the clear waxed version. He offered to supply the clear coat paint. But I would have to clean the wax off to paint. I opted for the satin black pipes. Then the wheels are not the traditional chrome, they are black also. So I'm leaning on having the fender painted to match the rest of the body parts. And I'm flipping quarters on chrome or black brackets for the headlights.
PostPosted: Mon Aug 26, 2024 10:45 am
Just so you are aware.... the stator/pickup assembly is NOT 1974 model. It is H1D (1973).
PostPosted: Mon Aug 26, 2024 11:05 am
Yes, it's noted in the original email 2015 from Steve III to the new owner JBoz on the first post. I appreciate your help and comments Dale. I assume I'll have to use the wiring diagram for the 73 H1D for that circuit.
PostPosted: Mon Aug 26, 2024 11:25 am
Correct!
PostPosted: Sat Aug 31, 2024 2:25 am
I've spent days looking up parts, new and used. I'm sure there will be more needed but I believe I have the lions share of it coming. I was disappointed about a few things that had to ordered, but that's what happens when you buy it disassembled and in tubs. It's still a dream come true. Order details
Product Total
KAWASAKI NEW Z1,H2,H1 Fuel Tank Cap Assembly × 1 $37.95
Kawasaki H1,H2,KH500,Z1,KZ Front Brake Switch × 1 $19.99
Kawasaki H1,H2,Z1 Front Brake Master Cylinder/ Single × 1 $79.95
Kawasaki H1,H2,Z1,KH Handlebars KZ,S2 NEW Superbike S3,S1,ZRX × 1 $34.99
KAWASAKI Z1,H2 Left BRAKE HOSE BRACKET H1,KZ,KZ1000A NEW × 1 $30.47
Kawasaki H1,KH500 Black Clutch Cable × 1 $36.95
Kawasaki H1 / KH500 H2B, H2C Starter ,Choke Cable Black 54017-063 54017-053 × 1 $43.95
Kawasaki H1,KH500 Throttle Cable,Combination Cable,BLK × 1 $57.95
Kawasaki H1/H2 RH Controls CDI Models 46132-003/46132-019 × 1 $75.00
Kawasaki H2 750, H1 500,KH500, KH400,250,S1 Left Control Switch × 1 $40.99
Kawasaki H1, H2, S1, S2, S3, KH 8pcs engine oil pump seal Kit / Free shipping! × 1 $24.99
Kawasaki H1,H2,S1,S2,S3,KH Oil Line Washer Set / Washers × 1 $15.00
Kawasaki H1,H2,KH500 Meter Bracket Dampers x 4 KH400,KH250,S1,S2,S3 92075-080 × 1 $43.44
Kawasaki H1 500,H2 750,KH,S1,S2,S3 Release Assy,Clutch German × 1 $139.95
Kawasaki Short Stalk H1,S,KH500 Turn Signal Set × 1 $129.95
NEW Kawasaki H2,H1,KH500,S2 Tail Lamp Assembly 23025-044 × 1 $64.95
Kawasaki H2,H1,S2 RearTurn Signal Earth Plates (2) × 2 $24.00
Kawasaki H1,H2,KH Spark Plug Case / Holder × 1 $37.99
Kawasaki H1/H2/KH500/S1/S2 Oil Pump Loc Washer S3/KH250/KH400 // 92024-058 × 1 $9.00
Kawasaki H1/H2/S1/KH Backrest Cover Damper Set 8 pcs / 92075-168 92075-169 × 1 $59.95
Kawasaki New Stainless Steel H1 500, KH500 Allen Engine Screw Kit × 1 $19.99
Kawasaki H1 500/KH500 Pair of Lower Side Cover Grommets × 1 $17.50
Kawasaki H1,H2 Gas Tank Strap/ Tank Band × 1 $24.99
Kawasaki H1,KH500 Spark Plug Holder Band × 1 $9.99
Kawasaki NEW A1,A7,S1,S3,H1,W1,W2,KZ Side Stand Damper × 1 $10.00
Kawasaki EBC H2/H1 Clutch Basket Tool CT004 × 1 $29.99
Subtotal: $1,119.87
Shipping: $60.90 via Priority Mail
Tax: $0.00
Payment method: PayPal
Total: $1,180.77
plus a Kawasaki H2,H1,Z1,KZ,S2,S3,KH NEW Side Stand Bolt + Nut × 1 $17.50 I can't Thank the administrators enough for the resource site.
PostPosted: Sat Aug 31, 2024 2:26 am
And the eBay order.
3x Kawasaki h2 h1 kh250 ke100 oil pump line hose Banjo Bolts oem screw joint tee US $27.95
KAWASAKI OIL PUMP BANJO CONNECTOR H2 H1 S1 S2 S3 KH250 KH400 KH500 92061-015 US $17.00
1974-75 KAWASAKI H1 500 Wiring harness bracket 26002-044 Triplestuff US $19.95
73-76 Kawasaki H1 KH 500 tail light lamp lens bracket license 23036-024-21 US $19.95
Kawasaki oil pump banjo bolt 92060-009 H1 H2 S1 S2 S3 KH500 KH400 KH250 US $19.50
KAWASAKI H2/H1 TACH DRIVE THRUST WASHER NOS! Quantity : 2 US $24.00
PAIR SIDE COVER EMBLEMS FIT KAWASAKI H1 / KH500/ MARCH III 1969~1975, #56018-146 US $44.50
NOS Genuine Kawasaki Point Cap Gasket H1 H2 KH500 Mach III IV 1969-1976 OEM US $4.89
NOS Kawasaki H1 H2 S3 KH250 Engine Cover Gasket 14045-022 US $7.19
NOS OEM KAWASAKI KZ400 KZ440 FOCUS ADJUSTING SCREW 23013-008 US $8.99 total w/shipping and taxes $234.09
