It is currently Fri May 02, 2025 8:30 am
 Post subject: what is this for
PostPosted: Tue Oct 06, 2015 4:00 pm
I don't deal with part numbers, what is this for? 25005-090
 Post subject: Re: what is this for
PostPosted: Tue Oct 06, 2015 4:09 pm
Is this a test?
25005-090 SPEEDOMETER ASSY MPH 1 "Meters" H1D
There's a fiche of it too.
PostPosted: Tue Oct 06, 2015 5:07 pm
Thanks, I didn't know what year it was for.
PostPosted: Tue Oct 06, 2015 5:37 pm
Barry, you sure it isn't for '73-'76 500s? One source I saw said it is, but I don't have all the hip information that some of the guys here have.
PostPosted: Tue Oct 06, 2015 5:52 pm
while all "late" H1 (and H2) speedos and tachos are interchangeable and will work, if this is indeed a TRUE 1973 H1d speedo (or tacho) it will have the letters "H1" located at the bottom of the gauge face.
This is the ONLY year that says "H1" on it
PostPosted: Tue Oct 06, 2015 6:14 pm
Verified from several sources Jim. Seems a 1-only H1D as Cody confirmed.
PostPosted: Tue Oct 06, 2015 7:52 pm
well, I'm screwed anyway, looks like it sat for 25 year upside down, the damper fluid is all over the face glass. And no H1. Brand freakin new in the box too! :thumbdown:
PostPosted: Tue Oct 06, 2015 7:53 pm
Maybe Don Fulsang could use it for a rebuild.
PostPosted: Tue Oct 06, 2015 8:23 pm
+1 for Don. He did both mine - fantastic craftsmanship. He does use/reuse old components as part of his restoration if no good cores are available.
PostPosted: Tue Oct 06, 2015 9:06 pm
That's a few hundred down the drain........
