It is currently Fri May 02, 2025 5:48 am
PostPosted: Wed Feb 05, 2014 10:02 am
Anybody know the type of black finish Kawasaki used on master cylinders and is it possible or practical to have them correctly refinished?
Thanks in advance!!
3 H2's, all stock
H2B, converted to H2C
75 Paint & Decals by Brian H
75 Euro Seat by Tony O'Connor
PostPosted: Wed Feb 05, 2014 10:34 am
They were black anodized, and you should be able to get that redone without a problem, if you seal off the parts that shouldn't be anodized. These days a batch is costing me about $150 minimum though. You could do it yourself from instructions on the web. The problem is that common black anodizing uses organic dye, and that fades in the sun quickly. If you were to use a brake fluid resistant paint, like Imron for example, it would hold its color much better. Maybe powder coating is resistant, and that would be cheap.
PostPosted: Wed Feb 05, 2014 11:37 am
Powdercoating works OK.
PostPosted: Wed Feb 05, 2014 1:00 pm
Do they have translucent (candy) powdercoating.......
PostPosted: Wed Feb 05, 2014 7:50 pm
Yes..not sure what they call it though
PostPosted: Wed Feb 05, 2014 8:08 pm
cool, if they had black, that would be perfect....... :thumbup:
