It is currently Sat May 17, 2025 8:40 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Aug 05, 2014 11:59 am
AS I POINTED OUT PREVIOUSLY, the Uni-Syn is a great and essential tool, I have 5, three different variations, can do anything from a twin to 12 cylinder, Webers, AFB and Holley, all sorts of carbs, but, some of us have found better ways for WE to do things than waste the time to move a tool from carb to carb to balance them, same as the Uni-Syn tools require..
As I also pointed out, that Walms also said, the manometer can use any form of liquids, mercury, french fry cooking oil, root beer, whatever, and, the Carb-Tune mentioned uses stainless steel floats to read the vacuum line draw, not bad at all. The original manometers that used mercury were produced and offered under the tool mane "Carb-Stix".
To make a blanket statement that my "facts" are only my own, is ludicrous, at best. All a person needs to do is to go visit for them selves, the topic about the Carb-Tune on KTOG that this topic evolved from, and read what those people have to say about using that tool, and the Uni-Syn, and one will find that they both work excellently. It then reduces down to what a person, each individual, has to say about what they use, and how it works, or doesn't, for EACH INDIVIDUAL, their experiences, NOT a statement that only the Uni-Syn is the easiest, bestest, mostest fun way to do it, and another persons 'facts" are not valid, nor wanted on these boards, simply because that person, personally disagrees with the poster.
To each, their own, but real facts are just that, many have found that a manometer, of any kind, works as well, or, in some cases, a lot better than the equally excellent Uni-Syn.
Two things are painfully true, past all this, balancing a 4 stroke multi-cylinder carb set is a PIA, and giant time waster with a Uni-Syn as the air filter ducting MUST be removed to use it, over a manometer, and both manometer and Uni-Syn methods are far, far better than the original 4 vacuum gauge sets that Honda offered for their first CB750 balance efforts. With those sets, there were 4 individual gauges, with a damper valve for each gauge. The idea, dampen the gauge from individual intake pulses, allowing the gauge to read steady, not oscillating. Well, the problem is, no two gauges read the same at ALL vacuum levels, they might read same at one vacuum level, but, anywhere else, no dice.
I leave it with the users here, do as you wish, both manometer, and Uni-Syn are =, to my view, essential tools for any good mechanic to have, shop or home use.
PostPosted: Tue Aug 05, 2014 1:27 pm
What it breaks down to, is there are a lot of tools for doing the same job. Some tools work better than others, depending on the persons preference. I have used a lot of different ones, and prefer the Uni-Sync, if someone else likes a manometer that's fine too.
PostPosted: Tue Aug 05, 2014 5:26 pm
Finally, you said exactly what I said, many times above.
PostPosted: Thu Aug 07, 2014 8:03 pm
X
Last edited by warehouse1001 on Mon May 15, 2017 10:34 pm, edited 1 time in total.
PostPosted: Thu Aug 07, 2014 8:21 pm
At least the pivoting type, I have it and the one with the tubing also.
PostPosted: Thu Aug 07, 2014 8:33 pm
X
PostPosted: Thu Aug 07, 2014 9:13 pm
It really just depends on how much room you have behind the carbs.
PostPosted: Thu Aug 07, 2014 10:01 pm
"some folks find the new Edelbrock tool (made in China) to be of somewhat inferior construction. "
I had an original and the pot metal aluminum broke in my hands.
I think they were a really good cheap tool that could be made from cheap material.
I have had them pull down the idle even at the most minimal setting though.
PostPosted: Sun Aug 10, 2014 2:15 pm
X
Users browsing this forum: kc15842
