It is currently Sat May 17, 2025 7:46 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Jul 25, 2014 6:13 pm
Oh boy :shock:
I just read it's not numbers matching, purchasing a set of good cases would be much easier.
Just for the sake of argument, let's say it's numbers matching and you need to get them welded. You would need copper plugs made to the exact diameter of all bores in the vicinity of that bore. Both case halves would need to be bolted together and heat absorbing putty put around the area to help reduce warping. Then you would need a really good welder to TIG it.
Then if you were really lucky, it would still be OK to use without additional machining.
PostPosted: Fri Jul 25, 2014 6:41 pm
JRD
10-4........don't care about matching numbers.......somebody must have blown up the original engine anyway.........I understand what you are saying........heat and warping issues........I don't like the galled crank bosses either.........another set of cases is what I will do then.........on the hunt for a set now :crazy:
Jeff.....Thanks for your Input........this guy does some good work :!:
THX Phil
PostPosted: Sat Jul 26, 2014 5:31 am
BBP, you're not alone with crank case cracks. Just split the case on an H1 and found similar cracks. Makes me wonder if this is a common problem that is just overlooked or not normally noticed.
Ken
Moyock, NC
"Feel the tension, man! What a ride!"
PostPosted: Sat Jul 26, 2014 5:54 am
The thought just occurred to me that these are 40 odd year old components, that have been used and abused, so it's always a good idea to check things carefully - no one is going to reproduce triple cases!!
PostPosted: Sat Jul 26, 2014 6:34 am
Well ALMOST nobody: http://www.exbilletengines.com/
PostPosted: Sat Jul 26, 2014 7:00 am
Hmm, wonder if that is current and relevant?! :think:
PostPosted: Sat Jul 26, 2014 7:06 am
Yikes! There goes the kids college fund! Can't be cheap. Could it be reasonable?!?
Ken
Moyock, NC
PostPosted: Sat Jul 26, 2014 7:26 am
Nigel S from KTC UK rides one, here is his bike:
pictures done by myself at KTC UK Southern rally 2011
PostPosted: Sat Jul 26, 2014 11:46 am
Myock13........Man, I feel your pain brother........I suppose thats what happens when people dump the clutch an do a big burnout or do a little speed shifting and miss a gear.........I've gotten on my bike a few times, but I always just roll it on when its in gear, let off, clutch and shift........after seeing 4 of the 6 crank bearings shot, one of the rods (left) wasted, left seal leaking air, release seal split in half, the shift arm lever nut loose, the clutch dimple washer has 2/3 of the dimples flattened out, and a few other fun things, lucky I didnt blow it up :!:
JP and Rod.......I have been salivating over those billet cases for a while now......with the newer KAW 6 speed trans and clutch.......I think it is Neville Lush's site (I beleive) that has a description and engineering details.......then machined in Belguim or somewhere....(In JP's backyard)........wonder what they cost and if available ?........probably 10K :o
Rod.......I have a set of shift forks being made (thru HVCcycle) in Aussieland.....do you know who is making them ?.......they are supposed to get 5 sets in a month or so
THX Phil
PostPosted: Sat Jul 26, 2014 12:52 pm
The billet engine is made by Leo (who is on this forum) and Ralf Schippman (who is perhaps on this forum under aka Billetengine). Both are crazy guys and crazy triple nuts. Not sure about the price but it'sn't cheap.
Am this year on big carbs and expansion chambers (Denco RR) on my H2A but will order one on 2016 I think :shh:
