It is currently Wed May 14, 2025 7:26 am
PostPosted: Fri Jul 18, 2014 5:43 pm
Over 5000 miles logged, lots of time running WOT.
Aaron
1980 KE100 (ZomBessie)
PostPosted: Sat Jul 19, 2014 12:39 am
I had a '76 KE 100. I seem to remember getting about 75 miles before a refill. That was 1.5 gallons. Cost was 54 cents to fill. I weighed around 135lbs then. That works out to around 50ish mpg. Looks like you are in the ball park.
PostPosted: Sat Jul 19, 2014 1:20 am
....always fun to "look back!" :lol:
PostPosted: Sat Jul 19, 2014 7:07 am
Went out with the "boyz" last week around the Leelanau peninsular, 100 mile round trip, maybe 40 miles at 50 MPH, 20 at 60 MPH 20 at 70 MPH and 20 at 90 MPH and the occasional Ton, generally "spirited Riding, we all filled up at the start together and we all filled up at the end together.
GPZ 750 Turbo : 41.3 mpg
1973 Z1 : 43.1 mpg
1974 S3 with Dencos : 36.73 mpg
1975 H2c Ported with Spec II pipes, flat slides Etc : 34.48 mpg
:thumbup:
PostPosted: Sat Jul 19, 2014 8:24 am
43 seems on the low side for a 100. My Yamaha DT100 got through the Dragon three times on one tank, and ran out as I came down the hill to the parking lot the last time. It has a 1.1 gallon tank on it, and each round trip is 22 miles, so 60 mpg with lots of WOT. Maybe the reed valve helps the Yam.
PostPosted: Tue Jul 22, 2014 8:56 am
I'm 6'2" and 200 lbs, not terribly big, but it may have a bit to do with it.
Wonder if there's much I can do to get some more MPGs.
That or find a bigger tank to put on it.
I want more range.
Aaron
PostPosted: Tue Jul 22, 2014 9:34 am
Maybe grab a flat gas can and either bolt it on or keep it in a backpack?
PostPosted: Tue Jul 22, 2014 2:22 pm
Make sure you're not running rich in the throttle region you use most of the gas in. If you drop the needle a notch, keep your ears open for pinging.
PostPosted: Tue Jul 22, 2014 4:08 pm
You are really just overloading a little bike, that 100 is for kids to putt around town and fiddle about in the woods or desert. Just carry extra fuel, I don't think you are going to get any better mileage out of the motor.
PostPosted: Wed Jul 23, 2014 7:47 am
Aside from the bolt that holds the carb in place, the carburetor is completely stock and there are no adjustment notches on the needle.
Overloading? I'm not that big... :P
I do most likely run it a bit harder than most people would and my distance rides definitely mean I ride it for much longer. But yeah, I kinda doubted that I would be able to get any better mileage. I'd love to find a bigger tank for it.
Aaron
