It is currently Wed May 07, 2025 3:19 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Nov 11, 2013 1:27 am
just like to say that i have bought many things from tanner at z1 he is a very nice guy. wish list 1969 kawasaki 500 perches clutch and front break .also correct carb kits 72-75 750 kawasaki. fork ears 69-71 kawasaki 500 and front head light . fork tubes for 69-71 500 they make after market ones now but there 300 a set bit pricy. 69-71 gas tanks 500 kawasaki hard to find and there big bucks on ebay.
PostPosted: Mon Nov 11, 2013 4:01 am
69-71 gas tank cap
Gary T
PostPosted: Mon Nov 11, 2013 5:59 am
scouse wrote:
69-71 gas tank cap
Gary T
repros are made Gary :shh:
PostPosted: Mon Nov 11, 2013 7:23 am
Reproduction Decals has the oil tank cap (nipple?) w/screen, choose Triples, Body, then scroll down about 2 pages...
http://www.reproductiondecals.com/default_frameset.html?content.html~main
$28 is NOT a lot of money compared to leaking your tank empty with a cracked one and seizing your engine... :x
PostPosted: Tue Dec 03, 2013 10:45 am
oval rubber for oiltank cover 72/73 H2 should be reproduced
72 H2 750 Tracy body
73 H2A 750 the Midnight Train (black and Blue)
69 H1 project
70 H1 project
PostPosted: Tue Dec 03, 2013 11:18 am
Colored anodizing, including black, is almost always clear anodizing that has been dyed with an organic dye. Organic dyes fade in sunlight, and black often goes through the purple color you have seen, before ending up a weak grey if left out long enough. There are anodizing processes that make the aluminum oxide layer have the desired color, but they are less common and more expensive.
PostPosted: Tue Dec 03, 2013 12:02 pm
I would say ball bearing clutch actuator but now I'm waiting on a hydraulic unit which is even better. :mrgreen:
PostPosted: Tue Dec 10, 2013 8:58 pm
Walms. The hydraulic unit sound nice, but wouldn't you then have a reservoir mounted on your bars?
Ralf's offering (the German unit) gives the light touch, but no visible difference to the bike. It's a great piece and bolts on. R&R.
PostPosted: Tue Dec 10, 2013 9:14 pm
Here is the list from member suggestions I'll be handing off to z1. Had hoped to have more, but let's see what they can do with these. Some requests may require a sample for tooling if they do not own that model. I'll contact those who posted if that is the case.
S1/S2/S3 :
72 S2 side covers (no emblem holes)
73 S2A oil tank side cover
S1 /S3 riders handbook pockets
Rubber plug (square) bottom of the oil pump cover
Seat pans and foam
H1 500 :
69 clutch and brake perches.
69-70 gas tank (primer only)
69-71 gas tank caps
69-71 correct fork ears
69-71 distributor caps and rotors (with brass inserts)
69-71 headlight
69-71 fork tubes (pricey at $300)
69-71 front fender
69-71 gas tanks
70-72 transparent riders handbook pocket
72-75 fork ears
Late seat cover (correct pleat placement)
Late fuse holder with wire
Late spare fuse holder (rubber)
Late gear shift adjusters
Late better throttle and clutch cable with the correct elbows and cable lengths and adjuster placements
Late clutch adjuster screw and locknut (9mm)
H2 750 :
72 front fender
72-75 correct carb kits
72-75 fork ears
72-73 oval rubber oil tank cover
Miscellaneous :
Bolt selection with the correct stamp on the top of the head (4/8/12 etc.) in applicable lengths.
Rubber float bowl gaskets that FIT
Fork dust boots (quality rubber)
Head bolt set (nuts actually) zinc, chrome and stainless (H1 8mm/H2 10mm)
Oil level sight window rubber grommet
Fuses (correct size and amps in stock)
PostPosted: Wed Dec 11, 2013 1:21 am
Please add fork ears for later years H1's and H2's.
