It is currently Mon Jul 07, 2025 5:07 pm
PostPosted: Tue Aug 02, 2011 10:08 am
How do you like the results on the Triple I vaporblasted last week? The sand-cast looking cylinders and heads turned out perfectly--they always do. The smooth, die-cast crankcases turned out clean and shiny and authentic.
Now, if I can't figure out how to post that picture here, you can find it on eBay motors, in my ad, just search the keyword "vaporblasting".
I'm Jeff Gibson at Vaporblasting by Bikesalot
PostPosted: Tue Aug 02, 2011 10:14 am
http://www.vaporblasting.biz/
PostPosted: Tue Aug 02, 2011 10:37 am
Can yo do that with painted parts....... :lol: :lol: :lol:
Looks great!
PostPosted: Tue Aug 02, 2011 4:36 pm
Higgsy just did one of mine (vapour blasting) in the Uk :D
ERM ,took a few days of "nitromors" to remove the black paint off the cylinders and heads :oops: :oops:
PostPosted: Thu Aug 04, 2011 11:18 am
I will never bead blast again, Grease comes right off and vapor blasting closes the pores. I offer vapor blasting if anybody wants a price send me a pm. Also Sudco Parts cheaper than anybody. :D
PostPosted: Fri Aug 05, 2011 11:03 am
Looks very nice! :thumbup:
PostPosted: Fri Aug 05, 2011 8:32 pm
To either Jeff or Mach3, what does cases and a set of heads and cylinders run to have blasted? Is there any kind of prep work that the customer should be responsible for to keep costs down, or just send them the way they come off.
On a sort of related topic, maybe moo can answer since he does the work. If heads are going to be worked and cylinders bored and ported, should the blasting(either vapor or glass bead) be done before the machine work or after.
PostPosted: Fri Aug 05, 2011 9:11 pm
What is the process of vapor blasting?
PostPosted: Fri Aug 05, 2011 9:17 pm
In a short non-technical term, it is media mixed with water to create sort of a slurrie that is then "blasted" onto the part similar to bead blasting.
PostPosted: Fri Aug 05, 2011 9:29 pm
I underatand that. Now how does that seal the pores?
