It is currently Sat Jul 12, 2025 11:24 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: The Axe Bike runs!
PostPosted: Mon Sep 02, 2013 8:57 pm
Cheers, R.B. I knew the reason for the high ign covers, but didn't realise it was the subject of a recall. In 1970 in Aus. you could buy a Red H1 with points - low cover, or with CDI - high cover. About $60-70 price difference!!
PostPosted: Mon Sep 02, 2013 11:24 pm
In Europe, it was found that the "new CDI" was causing bad interference on the TV's, so to combat this the European bikes were sold with points ignition systems from the Mid '69 run, these engines were built specifically and were given a new set of engine numbers starting at KAE50000 (approx), these all came with the low oil pump covers. At the demise of the H1a these engines were used up and sold in the H1c.
As an aside, the first 3,000 bikes KAE08000 - KAE11000 (from memory) were fitted with the new high covers, but these covers did not have the cut out for the rubbed vent in the bottom.
PostPosted: Tue Sep 03, 2013 5:51 am
http://kawtriple.com/mraxl/bulletins/73-h2.pdf
