It is currently Mon Jul 14, 2025 3:06 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Jul 19, 2013 1:55 pm
either way at least we have choices
:thumbup:
PostPosted: Fri Jul 26, 2013 6:23 pm
Mark,
I think I may be the customer that Jim was speaking of in an earlier post. I had purchased a VCDI-30 and programmer for my H2 from Borut. He had told me that he had never tried a VCDI-30 with anything other than a Zeel CDI but didn't see a reason why it wouldn't work. I had a new all in one unit from Jim and if the Zeel wouldn't work with it, I was just going to past. I received the unit, installed it and couldn't get spark. Jim worked with me for about a week maybe 2, troubleshooting and making suggestions. (Thanks again Jim!). I contacted Borut who was also helpful but in the end, I wound up sending the unit back to him and he did something to make it "more sensitive". He called it the VCDI-30S. The unit now works very well with Jim's CDI and I would imagine with a stock CDI as well.
One fly in the ointment was that I have a capacitor rather than a battery and the Zeel has to have a battery to boot the controller. I installed a small battery for the controller and wired it to the capacitor for charging, mounted an on off toggle switch under the seat and I'm GTG.
Another issue was that I had to use Resister plugs to get the progrmmer to function while running.
Now I have the programmable curve, a shift light and rev limiter. Mission accomplished!
Not sure if you remember but you made a couple of timing suggestions that also worked out well.
Hope this helps,
Bill
Trilogymac
PostPosted: Sat Jul 27, 2013 3:39 pm
yes, i remember.. very cool. :thumbup:
the issue i had was triggering off the late H1 pickup. borut seesm to think it can be made to work so.... hopefully, wee can get it worked out.
