It is currently Sat Jul 12, 2025 7:51 pm
PostPosted: Mon May 27, 2013 4:51 pm
The front skirt is never cut, will ruin the piston.
PostPosted: Mon May 27, 2013 6:52 pm
Okay. I was thinking it was cast and would have a radius instead of that sharp of a corner. That is good news - The pistons measured 57.5mm diameter, so it looks like they are stock. Right?
PostPosted: Mon May 27, 2013 6:55 pm
First over, std. is 57mm. :wave:
PostPosted: Mon May 27, 2013 7:26 pm
Cylinders are all boxed up and alot pf cardboard is headed your way. :lol: I did hone them up a little and knock the glaze out. I don't like honing cylinders too far so I only took then to where I'd stop and run em. Don't want it to rattle too much. :thumbup:
PostPosted: Mon May 27, 2013 8:17 pm
Thanks! I measured the piston at the very bottom and actually go 57.40mm. Is this the right place to measure?
PostPosted: Mon May 27, 2013 8:53 pm
You measure the bore, and yes, they are first over.
PostPosted: Wed May 29, 2013 1:01 pm
http://www.3cyl.com/mraxl/manuals/maint ... .htm#clean insp
5mm up from base of piston skirt as shown in pic. :thumbup:
mark
PostPosted: Wed May 29, 2013 1:27 pm
You measure there if you are figuring piston clearance, but not necessary just trying to figure out what bore you are at.
PostPosted: Wed May 29, 2013 7:52 pm
Mark, I asked because I had thought it looked like the piston is stamped 0.00 and I was thinking that meant it was stock size, right. When I saw that the measurement was indeed made correctly, I run out to the garage to get photographic evidence and guess what - it still looks like 0.00 to my admittedly lacking eyesight. However, when I upload the photo and look at it on the relatively large screen, I see... you guessed it, it was 0.50 :wtf:
Now looking at the photo, I can't believe I mistook the 5 as a 0 and I have confirmed your suspecion that I'm a little off!!! :crazy:
PostPosted: Wed May 29, 2013 8:13 pm
its all good phill :thumbup:
you will have that wee beasty running before you know it .
you will have the happy dilema of "girly or crazy" smokers
cheers mark
