It is currently Sun May 11, 2025 11:56 am
PostPosted: Sat Feb 23, 2013 9:02 pm
What was keeping the turbo lubed?
PostPosted: Sat Feb 23, 2013 10:20 pm
Mostly intimidation, I gave it a stern talking to before I ran it :D
Actually, I capped off the oil exit port on the bottom, and poured gear lube in the top. Basically, the bearing was just surrounded by oil. This is why I never ran it for more than a few minutes at a time. I knew going into it that it wasn't a long term solution, but good enough for the class project it was built for. I've probably run it 45 minutes total, and there is no appreciable bearing wear. If/when I fire it up again, I'll replace the bearing and rig up a proper pressurized oiling system.
PostPosted: Sun Feb 24, 2013 6:03 pm
That has to come to the Gap meet !!!
:idea:
PostPosted: Sun Feb 24, 2013 7:08 pm
:idea:
We could use that at the fire pit at Deals Gap. No need for kindling. A 2s leaf blower though would be required for the start since it is a two stroke meet. :D
