It is currently Mon May 12, 2025 3:56 am
 Post subject: Some beautiful welds....
PostPosted: Fri Jan 04, 2013 2:05 pm
http://www.silverstonesuperbikes.co.uk/xr69_5.html
PostPosted: Fri Jan 04, 2013 2:12 pm
The close up of the frame looks to be brazed...
Very nice though!!!
PostPosted: Fri Jan 04, 2013 2:37 pm
The description "NICKEL BRONZE WELDED" is another clue, but I think "welded" is not really correct if it was done with nickel bronze. I remember those photos from a previous thread somewhere.
PostPosted: Fri Jan 04, 2013 2:54 pm
There is some discussion, it seems to be TIG brazing......... :wtf:
PostPosted: Fri Jan 04, 2013 3:04 pm
I am not sure if it was that frame or not, but there were some similar pics floating around on the boards a while back. Here is a vid of it being done. I would assume that a tig torch could be used in place of the O/A. If the comments are correct, it tells the difference of brazing and bronze welding. http://www.youtube.com/watch?v=ZlLV0P6uGDw
PostPosted: Fri Jan 04, 2013 3:10 pm
Yup, I had a total flash back when I saw the pic... :lol:
I also agree with Jim... Brazing is closer to soldering than welding imo.
I'm not knocking it though, I believe the previous thread stated that this method was better than TIG welding... Not sure if I really see it though???
PostPosted: Fri Jan 04, 2013 4:19 pm
If the tubing being joined has a temper that would be adversely effected by the heat of welding, the lower temperature of brazing can sometimes prevent the problem. High-end bicycles in the heyday of steel frames had to be low temperature brazed because they used exotic steels with tempers that would be lost by welding. I have no idea if that might be the reason the motorcycle frame was brazed.
PostPosted: Fri Jan 04, 2013 4:48 pm
Yeah, I sort of remember that rational... I just looked up the melting point of nickel bronze to be 1035-1055 deg c. This is well above the temperature that would effect the temper in the steel though... Wouldn't you agree?
It obviously works, I'm just trying to understand why???
PostPosted: Fri Jan 04, 2013 5:03 pm
Maybe the heat of welding didn't change the temper as much as change the crystal structure in some other way. (?) The bicycle frames were brazed with a silver bronze alloy, but as you pointed out, I think even that stuff needed a temperature that would change a temper. I knew the guys in a frame building shop, and they had to get special training to braze the Reynolds tubing. (not the same Reynolds that makes Aluminum)
PostPosted: Fri Jan 04, 2013 7:17 pm
I thought I read that it won't introduce some of the stresses to the steel that a true welding process would.
