It is currently Fri May 16, 2025 1:28 am
PostPosted: Mon Oct 15, 2012 5:01 pm
Walms wrote:
Get with the program Jim!!! Sliders are supposed to be made of magnesium to insure an impressive slide and to ignite the gas that has spilled.
now you're talkin!
PostPosted: Mon Oct 15, 2012 5:02 pm
And carry around a 100 lbs. of diesel soaked fertilizer for effect....... :wtf: :lol: :wtf:
PostPosted: Tue Oct 16, 2012 2:11 am
Titanium works better, just drill and tap for a M6 button head screw on the end of the slider.
One of the stupidest things I've ever done was to make a set of Titanium brush cutter blades..............used them once, put the fire out :oops:
PostPosted: Tue Oct 16, 2012 2:55 am
Have you seen the sliders I made? They're 1.25" 6061 aluminum bar with 2 inch PVC caps pressed on the ends. A 1/2" bolt goes through the engine mounts into threaded holes in the aluminum bar.
http://www.kawi2strokes.com/forum/viewtopic.php?f=2&t=3323&p=32583&hilit=sliders#p32583
nice work Jim but not from the period :mrgreen:
PostPosted: Tue Oct 16, 2012 8:34 am
That's OK JP, not much else on my H2 is from the period either. :lol:
PostPosted: Tue Oct 16, 2012 9:49 am
Except the zerk fitting on the steering head.. :clap:
PostPosted: Tue Oct 16, 2012 10:11 am
The rider? :P
PostPosted: Tue Oct 16, 2012 10:49 am
The Zerk fitting on the rider's head.
PostPosted: Tue Oct 16, 2012 7:23 pm
The last two S1 project bikes I picked up both had original 70's crash bars fitted. I kept banging my knees on them, so I took them off. Offered them on here, but no interest. Put them on Ebay, but no bids. Took them to the metal recyclers in the end. They probably would have fitted most Triples as they bolted to the frame and could be adjusted. But nobody wanted them. Oh well.
