It is currently Wed May 14, 2025 6:58 pm
PostPosted: Fri Jun 29, 2012 9:07 pm
Great you found it! I bet that was the problem.....
PostPosted: Sat Jun 30, 2012 7:54 am
Been away from the board for a while.
Hope you have found the source of problem.
Were the needle jets removed, inspected & cleaned?
Were the carbs soaked in carb cleaner or just sprayed?
The difference in enrichener tubes is normal... don't alter them.
PostPosted: Sat Jun 30, 2012 8:00 am
Yes, I did all the good things that you should do with carbs - completely disassembled and soaked, probed, blasted with air. The big thing that I missed was the air jet. I never saw it until yesterday and it was blocked. Thus, no pilot circuit function.
Thanks again for all the good advice and encouragement. I will put the carbs back on the bike today before the garage gets up to 100 degrees.
Rotortech
Indianapolis
1974 S3
PostPosted: Sat Jun 30, 2012 6:32 pm
Glad to see you're getting her together. :thumbup: The carbs can be tricky. I seem to find the hole in the pilot circuit facing the intake seems to clog up the easiest.
PostPosted: Sat Jun 30, 2012 7:30 pm
I rode it today. It did better but the pilot circuit is still not quite right. That's OK. I can remove the carbs in my sleep now. :D There is some tiny lump of dirt hiding out in there and I will find it. All three are affected but the RH cylinder is the worst.
Here is what my S3 looked like right before I took it off the build stand. Since then I added gas cap, mirrors, and chain guard. Maybe a couple of other little things - I forgot.
Rotortech
Indianapolis
1974 S3
PostPosted: Sat Jun 30, 2012 7:48 pm
I really like the paint, and the lack of decals. :D Is that the kind of paint job that you drag plastic wrap through?
PostPosted: Sun Jul 01, 2012 6:13 am
Yes, I think the paint is done with plastic wrap. The guy I bought it from was a custom paint guy. Not a mechanic.
Over the winter I plan on getting new pipes, paint and seat upholstery. Then it will be almost entirely finished.
Rotortech
Indianapolis
1974 S3
PostPosted: Sun Jul 01, 2012 7:10 am
Gm Rotortech, I'm a little late on this thread,I was just wondering if you have a good strong battery in your bike ? The smaller triples don't run good with a weak battery. My bike is a kh 250 with a 350 topend with 400 carbs and chambers.If i don't have a good fully charged battery the low end on my bike is awful.Just a thought.
PostPosted: Sun Jul 01, 2012 9:39 am
:cry:
PostPosted: Sun Jul 01, 2012 10:19 am
Harry,
Thanks for bringing that up. I am blessed with a strong battery and a good charging system on this bike. EDIT - FOUND PROBLEM IN CHARGING SYSTEM. DETAILS LATER IN THIS THREAD. I think the spark is consistent. It starts on first or second kick and idles nicely. As soon as I apply some throttle it starts cutting out and stumbling all over itself. All symptoms point to the pilot system and I am dipping the carbs again today.
Rotortech
Indianapolis
1974 S3
