JoeMcdonald wrote:
Thanks Jim - I didn’t realize I couldn’t use the Rx10 values for digital
- I assumed they were interchangeable with a slight conversion. I thought maybe there was something wrong with the meter. Don’t laugh, I actually went to radio shack and brought a few raw resisters with various ohms just to check if my meter was good. I guess the amount of current fed from digital is different and maybe turning something on (transistor) or half way on inside. Oh well, maybe Ill get an analog to play with... aside from that there are better test methods, is there a value chart for digital???
I don't like to use resistance measurements for things like diodes and transistors because they can vary so widely. Checking a meter against known values like you did when you checked your Ohm meter with resistors is not silly, it's the way one verifies that his equipment is working properly.
You hit the nail on the head when you mentioned the difference in current being applied to make the measurement. With pure resistances, it wouldn't matter, but with semiconductors it does matter, as does the voltage the meter has available. Try measuring the resistance of a single diode sometime, in the direction it conducts, using different meters, and you'll see the problem.
