It is currently Wed Apr 30, 2025 7:49 am
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
 Post subject: Re: 1974 H1 Project
PostPosted: Thu Jun 14, 2012 8:26 am
tango911 wrote:
good thing im doing a semi cafe and not a 100 point resto eh?
Yup! And in my opinion, those gauges are much racier looking...I've always liked them.
PostPosted: Thu Jun 14, 2012 9:38 am
doesn't really matter just an information and you all know am not a 100 points resto guy :P
PostPosted: Thu Jun 14, 2012 12:29 pm
its def good to know i appreciate it. Thats why i joined the site.
PostPosted: Thu Jul 12, 2012 8:14 am
finally got to work in the garage for a little last night, pulled the engine. Its interesting what you find under the carbs. Found some leaves, a few screws and a screwdriver tool. I have a friend thats rebuilding a 73 h1 and we have a powdercoater that will do both frames and 4 rims for $400.00 thats the best deal i can find around here.
PostPosted: Fri Jul 13, 2012 4:50 am
Hi Tango I`ll be following your rebuild with interest as I am just finishing one now. Can`t tell you anything you won`t get off these guys though. I had also done a few four strokes and thought I`d kill it on the triple as strokers are simpler right? Yeah right, but everthing needs to be spot on I tell you. If it`s not running just right get advice, don`t do what I did and try to work it out yourself as manuals are all differrent and sometimes just wrong and if it`s not right it could end in major malfunction as I now know. Good luck. Steve.
PostPosted: Fri Jul 13, 2012 8:13 am
Thanks for the input Green!
Here are some more pics. Took the front end off and found that the fork tubes are bent, must have been in a wreck. going to power wash the frame and double check that its not bent before i go too far. Found a crack and a protrusion in the right engine cover just under the oil pump. I was hoping not to have to rebuild the engine but might have to just do it. Ill post everything i find out on here to get input. Pic of the crack below.
finally down to the frame, sending it for powdercoating in a couple days
Uh oh!!!!
PostPosted: Fri Jul 13, 2012 10:18 am
Anyone wanna bet the star lock washer isn't on the oil pump drive bolt?
PostPosted: Sun Jul 22, 2012 8:48 am
Looks like the right spot. :thumbup:
PostPosted: Sun Jul 22, 2012 2:03 pm
Had the same thing with my resto
I think it also explains why the crank bearings were toast. I filled it in with jb weld.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Tue Jul 24, 2012 9:21 am
in the meantime I have the rest of the bike taken apart. Found out the fork tubes were bent. so i ordered new repros. The frame is now powdercoated along with the rims, now its time to clean, paint , polish all the small stuff and start putting the bike back together.
