It is currently Thu Oct 31, 2024 7:11 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun May 27, 2012 12:47 am
Looney Cylinders wrote:
Neat trick! ;) If it were me I'd be tempted to turn the idle up a bunch to get home :?
J
Well, when it broke and jammed up in there, I pulled in the clutch, and my shift light went nuts. It does that starting at 8500, and I bet it hit 10k before I turned off the ignition switch. Even then it kept going for a while, so I guess it was dieseling at that point. At least I know my slotted intake skirts and crank will probably last the season, since they survived that fiasco.
PostPosted: Sun May 27, 2012 1:12 am
and I bet it hit 10k before I turned off the ignition switch....... At least I know my slotted intake skirts and crank will probably last the season, since they survived that fiasco.
:o :o :o :o :o :o :o :o :o :o :o :o :o :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Or when you start finding main bearing cage shrapnel in a combustion chamber you'll know why! :(
It seems both you and Walms do not have your Veypor units programmed to record max rpms attained. :? (nice to have a recall to possibly put your mind at ease for stuff like this)
J
PostPosted: Sun May 27, 2012 8:24 am
I don't let a little thing like that bother me, Scott. It's revved faster than that before. :P
PostPosted: Tue May 29, 2012 12:18 pm
i drove for a week with the throttle cable for a saab 900 routed through the open drivers window.
not to be recomended :lol:
PostPosted: Tue May 29, 2012 2:43 pm
Jim 10K.. :shock: :shock: motor still ok :shock: :shock:
PostPosted: Tue May 29, 2012 3:42 pm
Oh yes, thanks, it's fine. I've put another hundred or so on it since the incident and it's as happy as can be. My daughter and I just got back from a 40 mile ride in the countryside, and she loved it as usual.
PostPosted: Tue May 29, 2012 6:44 pm
Is that the recommended run-in procedure for a new engine, Jim.....?? :crazy:
PostPosted: Tue May 29, 2012 7:40 pm
It doesn't matter, Rod, I was done breaking it in after my first 10 mile ride. :lol:
By the way, the Wossners look great. It's wonderful to not have to worry about the Kaw recommended thousand mile break in.
PostPosted: Tue May 29, 2012 7:55 pm
:thumbup: Any rattles yet? :lol:
PostPosted: Tue May 29, 2012 8:01 pm
Only the loose rods, but I'll probably get to those this winter. :lol: That bottom end has been through some really interesting times, and the case halves have never been parted. I hate to disturb things, but I guess it's about time.
