It is currently Mon May 12, 2025 1:21 pm
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 Post subject: Re: First start up
PostPosted: Fri Mar 30, 2012 6:34 am
Did you re-torque the heads when cold after each heat cycle?
I did not. Oops...
Now what? Can I retorque them or should I replace the gaskets?
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Fri Mar 30, 2012 9:40 am
Great ja-moo, how many cycles should I do that, I was told maybe 3 times :?: :?: :?: :?: :?:
Until the torque settles to where it should be.....
Thanks, Great advise. :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Fri Mar 30, 2012 11:49 am
I did not. Oops...
You can try just torquing them, or just anneal the gaskets and try that.
PostPosted: Fri Mar 30, 2012 5:46 pm
I'm on it! Thanks for the help.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Fri Mar 30, 2012 5:53 pm
All 12 in a criscross pattern. The factory manual has it numbered.
Bringing it to the Gap this year? You are only 2 hrs from the Gap from ATL.
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Mon Apr 09, 2012 1:33 am
with not running a top trumpet, you will be running lean, I would up my main Jet, maybe start with a 102.5, this takes into account the K&N
Gary T
PostPosted: Mon Apr 09, 2012 11:32 am
Thanks Gary, I had it out yesterday and it does seem to be a little lean in the midrange. I attributed that to using the needles from the rebuild kit. I plan on putting the stock needles back in this week. I'll order some new mains. What about pilots?
Still too many bugs to work out before I bring it to the Gap. Working on it though...
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Mon Apr 09, 2012 1:32 pm
ThatGPzGuy wrote:
Thanks Gary, I had it out yesterday and it does seem to be a little lean in the midrange. I plan on putting the stock needles back in this week. I'll order some new mains. What about pilots? ..
as to the pilots stock is #30 and looking at the jetting chart most have gone to #35 and one has the #32.5 of those using stock exhaust systems. so i would go with the #35 and if thats to much come back down to the #32.5.
i still have a bit of a wait for jims pipes so i may end up putting the crappy/rusty pipes on to get it running.
if i do i will be using the 35 pilot and 102.5 mains on my HID with stock motor with pods .
cheers mark
PostPosted: Mon Apr 09, 2012 1:53 pm
Maybe one of these days folks will learn that the airscrew setting for highest rpm will tell you what size pilot is required... it isn't guesswork. :banghead
PostPosted: Mon Apr 09, 2012 3:03 pm
pardon my ignorance, i will have to do more research before i get carried away offering well meaning if poorly studied advise. :oops:
