It is currently Wed May 14, 2025 6:48 pm
 Post subject: Re: Coils?
PostPosted: Sat Mar 24, 2012 3:30 pm
He could do with some advice if you live close? He bought a CDI off me to replace the faulty original A and B boxes (H1a) but also has carburettor problems too. So, you may like to help another frustrated triple owner. He has several bikes evidently.
PostPosted: Sat Mar 24, 2012 3:45 pm
He's working on a 70 h1 if thats casey from jersey.. And he can definitely use some help.. ;)
PostPosted: Sat Mar 24, 2012 4:06 pm
Yes... thats him! ;)
PostPosted: Sat Mar 24, 2012 5:35 pm
Well...I'm 35 miles away and he's about 1/2 way between me and my folks. So I'm close. I'll help if I can.
Jeff
PostPosted: Tue Mar 12, 2013 7:23 pm
What '72 are you rebuilding? I did some testing of H2 coils in this old thread: http://www.kawasakitriplesworldwide.com/phpBB2/viewtopic.php?f=2&t=53001
Generally, the ones that Starfire recommended ^ are the smallest, cheapest ones, and work fine if not enclosed without air flow. The approx. $100 black reproduction H2 coils fit without any modifications or brackets, and the Dynatek DC9-4 coils made slightly better sparks than stock.
Jim,
Apparently the old site is dead and I wanted to look at your coils thread. I may be in the market for new coils for my H1F and wondering what the best options are...
Jim
PostPosted: Tue Mar 12, 2013 7:34 pm
Jim, late H1 coils need to have both primary leads available because neither one is tied to ground. That lets out the H2 reproduction coils I tested. I think you could use the little, inexpensive moped coils (green=ground, black=positive), and all reports are good for those. Also, I think the Dynatek coils would be OK, but they're bigger than stock, not cheap, and sold in pairs. I think those are part number DC9-4. If you use the moped coils, check to be sure they don't have resistor caps, and change them if they do.
I have a set of files for that coil test thread, so the information is not lost.
PostPosted: Tue Mar 12, 2013 8:03 pm
Thanks Jim,
Are OEM coils unobtainium or uber expensive? I don't mind buying the right parts if it's within reason. "little inexpensive moped coils" is a little vague. Are they that generic, as long as the lead colors are as described?
PostPosted: Tue Mar 12, 2013 8:37 pm
i just ordered little mped coils, have them on the s2 and the frog. they work great.
like these. i swear... its crazy how cheap they are. you will need to replace the plug caps as those are crap.
order 6, have a spare set.
http://www.ebay.com/itm/New-Performance-COIL-IGNITION-GY6-Go-Kart-Taotao-150cc-50cc-Scooter-ATV-/400431477313?pt=Motors_ATV_Parts_Accessories&hash=item5d3b937241&vxp=mtr
as long as they look like this you are golden
heres the 3 tucked under the tank on the S2:
PostPosted: Tue Mar 12, 2013 10:04 pm
Sweet, thanks Mark :thumbup:
