It is currently Thu Oct 31, 2024 6:59 pm
 Post subject: speedo not working
PostPosted: Tue Feb 21, 2012 7:25 am
Ok KH500 again. Cable appears good condition . It spins and I have oiled it. Both connections seem to tighten up ok. Is tehre something I am missing ? I have taken a apart and put back together the front wheel , all components. Could there be somethign there ?
Steve
 Post subject: Re: speedo not working
PostPosted: Tue Feb 21, 2012 7:35 am
Attach the tach cable to the speedo and see if the speedo shows movement with rpm changes. That will tell you whether on not the speedo itself is ok.
PostPosted: Tue Feb 21, 2012 7:38 am
Will do. I like the scientific approach.
Steve
PostPosted: Tue Feb 21, 2012 9:10 am
Great tip!
Sometimes a "good" cable will have a stretched or worn outer sleeve so that when both ends appear to be properly assembled, one end or the other is not engaged.
Rotortech
Indianapolis
1974 S3
PostPosted: Tue Feb 21, 2012 9:37 am
Use a drill on the end of the cable, just be careful not to kink it.
PostPosted: Tue Feb 21, 2012 9:57 am
If you use a drill be sure it is running in reverse.
PostPosted: Tue Feb 21, 2012 10:24 am
argh - thanks dale, forgot about that. frack....
bb
PostPosted: Sat Feb 25, 2012 10:31 pm
Great tip. The Speedo spins to about 30 kms on reverse on the drill. That rules out the speedo as the problem.
I guess I just need now to resit the cable and go for a ride and test ? Only problems its 35 C outside. Too damn hot for anything.
Steve
PostPosted: Sat Feb 25, 2012 11:00 pm
Watch your fingers and such, but you can spin the tire to get a few mph reading. You can also install the bottom cable and spin the tire to see if the cable is also.
PostPosted: Sun Feb 26, 2012 12:59 am
Is the speedo drive "bow tie" shaped plate properly engaged within the lugs on the end of the wheel hub? Often the front wheel/axle is assembled incorrectly and this driving plate gets bent back and no longer engages....
J
