It is currently Thu Oct 31, 2024 8:00 pm
PostPosted: Fri Feb 17, 2012 4:42 pm
I decided to chase down a few leaks today, the drive sprocket shaft being one of them. Oil appears to be leaking out from the center of the spacer.
Is there supposed to be an o ring behind it or something? The transmission seals are new. Oil seems to be leaking from between the drive shaft and the "collar" or metal spacer. This is on a H2a
PostPosted: Fri Feb 17, 2012 5:07 pm
There is a o ring on the other end of the collar that gets destroyed when you tighten down the sprocket. That's probably it.
PostPosted: Fri Feb 17, 2012 5:10 pm
towards the transmission, right? can't see how it would work towards the sprocket. It never had one when I disassembled it.
PostPosted: Fri Feb 17, 2012 5:13 pm
44 92055-035 « O » RING 1 (H2 manual)
PostPosted: Fri Feb 17, 2012 5:16 pm
behind the sleeve away from the sprocket.
PostPosted: Fri Feb 17, 2012 6:13 pm
Great, thanks guys!
PostPosted: Fri Feb 17, 2012 6:16 pm
The placement of the O-ring has been discussed before and its placement is not shown correctly in a lot of manuals and parts books. Look here: http://www.3cyl.com/mraxl/manuals/maint ... .htm#trans
and pay close attention to the note in red.
PostPosted: Fri Feb 17, 2012 6:29 pm
Note: The O-Ring shown behind the engine sprocket should be located between the spacer and ball bearing.
Wow, thanks Dale, Manuals are all wrong! Wholly buckets.
PostPosted: Fri Feb 17, 2012 6:56 pm
A trap for young players, that one, and another reason tips like that make this site so valuable - and the resource site, of course!
PostPosted: Fri Feb 17, 2012 7:13 pm
The steel spacer collar should also have one end of it with a larger chamfer than the other. The larger chamfer goes in, it holds the O ring in position. The O ring actually takes the shape of the chamfer, and the bearing relief in the inner race to shaft interface as it is pancaked into place.
