It is currently Mon May 12, 2025 12:39 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: First start up
PostPosted: Sat Feb 11, 2012 5:14 pm
ThatGPzGuy wrote:
Tried it again. The right cylinder is still cold. The other two warm up quick. What else can I check?
What did you try? Did you pull up on that carb cable?
PostPosted: Sat Feb 11, 2012 5:32 pm
Success!!!
I pulled the baffles and the right exhaust baffle was completely stopped up. I started it up and it blew a bunch of crap out the end. Woo Hoo!!!! :D
I took it for a little spin and besides a stiff clutch pull and spongey front brake it did pretty well. It's probably a little lean since the jetting is stock and I am running a K&N with no snorkel and no baffles.But at least it runs on all three!!!!
Thanks everyone. I could not have done this without the help from this and the other forum.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sat Feb 11, 2012 9:34 pm
Here are some pics of the baffles. Should I just leave these out or clean 'em and put them back in? The one on the bottom is clogged.
And here she is after the first real road test:
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sat Feb 11, 2012 9:40 pm
Clean them and reinstall
PostPosted: Sat Feb 11, 2012 9:46 pm
You can burn the carbon off...... :thumbup:
PostPosted: Sat Feb 11, 2012 11:52 pm
The baffles are an important part of the tuned exhaust system. You're have more power with clean baffles than without then.
PostPosted: Sun Feb 12, 2012 12:12 am
+1, tried a lot of methods, burning it off by far the easiest.
PostPosted: Sun Feb 12, 2012 8:20 am
blow torch, mole grips(vice grips) , wire brush ,then repack with fresh matting and safety wire.
you will be happily surprised at the improvement.
great rebuild so far jim. :thumbup:
cheers mark
PostPosted: Sun Feb 12, 2012 5:53 pm
Ok I'll burn 'em. Are they wrapped the whole way or just the last few inches?
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sun Feb 12, 2012 6:00 pm
Wrap them like you see in your pic.
