It is currently Mon May 12, 2025 1:42 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
 Post subject: Re: First start up
PostPosted: Sun Jan 22, 2012 10:18 am
And don't forget to video the first start up so if you do something really dumb we can all laugh at you. No pressure though.
PostPosted: Sun Jan 22, 2012 10:31 am
Oh how many of us been there where a camera was around at the most inopertune moment. :lol:
PostPosted: Sun Jan 22, 2012 1:52 pm
A whole lot of nothing happened so...
I am not getting any spark. Since this was a parts bike I don't know what is good or not good or where I may be missing a connection. The ignition light goes on and the headlight and brakelight but not the nuetral indicator.
Where should I start?
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sun Jan 22, 2012 3:13 pm
Make sure the engine is grounded.
PostPosted: Sun Jan 22, 2012 4:09 pm
It's grounded.
Should the CDI hum or click or something when the key is on? I don't hear anything.
I've looked into the test procedures so maybe I'll try that.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sun Jan 22, 2012 4:16 pm
no noise. You sure the kill switch is in the on position?
Late H1 CDIs don't make any noise. I'm not sure what test procedures you've seen, but these are really the only ones worth doing unless you have the factory testing machine:
http://www.kawtriple.com/mraxl/cditests.htm.
PostPosted: Sun Jan 22, 2012 4:32 pm
An easy cdi test is to measure the DC voltage at the positive side if the ignition coil while kicking it over with ignition on. You should have >50vdc else the cdi is bad or not hooked up properly.
PostPosted: Sun Jan 22, 2012 4:44 pm
I think so. The switch on top is in the run position. And the switch on the bottom was on the On postion. Is that correct? What is PO? I tried that too. Nothing.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sun Jan 22, 2012 4:45 pm
Ok I'll try that too. Thanks!
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
