It is currently Mon Jul 14, 2025 8:50 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Apr 22, 2012 9:45 pm
scrambler73 wrote:
Mike...
did you inspect the inside of the clutch cover to see if there are any "witness marks" from the clutch-plate tabs hitting/rubbing/chirping??
If there aren't any marks, its probably not going to be the tabs.
It did look like a few light scratches, but know I'm thinking that was caused from my polishing guy. I just don't know what to do, Thanks for any input. The motor was just redone from top to bottom, crank, pistons, the works.
Mike
PostPosted: Sun Apr 22, 2012 10:28 pm
The rivits get a bit loose, and the rubber blocks get hard. So there might be some wobble. Nothing unusual.....
PostPosted: Sun Apr 22, 2012 10:53 pm
Would that cause my noise do you think. What rubber Blocks MOO,????
PostPosted: Sun Apr 22, 2012 11:14 pm
Put up a vid...... :thumbup: There are bubber blocks in the clutch gear assembly. you would have to drill out the rivits to get to them. If nothing is scraping, then leave it noisy.
PostPosted: Sun Apr 22, 2012 11:25 pm
Those damn bubber blocks will get you every time.
PostPosted: Mon Apr 23, 2012 6:58 am
:lol:
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Mon Apr 23, 2012 7:20 am
ThreePipesSmokin wrote:
I replace my clutch cover gasket about every 6th or 8th time I take the cover off. Use some sealer on the engine side, and anti-seize on the cover side to make it easier.
I use sealer on the cover side and anti-seize on the engine side. :e11 The cover is one piece and even if you split the cases you can re-use the gasket, it's already on the cover. :thumbup:
Me too, stuck on cover (easier to scrape off).
PostPosted: Sun Dec 04, 2022 9:42 am
EBC Clutch plates.
NOT FIT FOR PURPOSE.
All they need to do is supply TWO of the reduced diameter plates instead of one.
WFO for 51 years
1974 Norton Commando 850 Roadster
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
2014 Rocket III Touring
PostPosted: Sun Dec 04, 2022 10:35 am
That's still some excessively brittle plate material.
