It is currently Sat Jul 12, 2025 5:53 pm
 Post subject: Seeping oil tank
PostPosted: Mon Aug 03, 2020 11:21 am
Well it looks like I discovered the oil leak. My oil tank is seeping at the seams. Probably futile but is there a way to seal these?
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
 Post subject: Re: Seeping oil tank
PostPosted: Tue Aug 04, 2020 10:18 am
Nothing lost by trying, plastic welder, or a good old soldering iron. Melt and add material .
PostPosted: Tue Aug 04, 2020 2:47 pm
Our opaque tanks are all PVC plastic, the black ones are ABS. Common hardware store plumbing cement works, PCV for PVC, ABS for ABS.
Now, anybody have a different bike with injection molded covers, tail section, fairing, they are all,ABS. Use regular fiberglass cloth and ABS cement, stronger than new. My Yamaha RZ500 has a few places on side covers with mounting tabs glued back in place.
PostPosted: Tue Aug 04, 2020 3:01 pm
Ok Thanks Guys. I'll try the ABS cement and a patch.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Tue Aug 04, 2020 5:55 pm
I would have thought they were all polyethylene. I'm pretty sure my translucent '72 tank is. If your black one is ABS, you can smear a little cement on it, let it dry, and see if it's extremely stuck, or if it peels off.
Edit: I put some PVC cement on one of my translucent '72 tanks and it didn't stick... I can peel it off in one piece.
PostPosted: Tue Aug 04, 2020 6:28 pm
What I posted always works, never had a problem, but, what Jim said, try it first to confirm. I've had great luck using the fiberglass cloth and the cements, it always makes a strong bond and has insane strength.
(Ronald Reagan), "Trust, But, Verify".
PostPosted: Mon Aug 10, 2020 10:04 am
Well, the first attempt was a failure. The ABS/fiberglass mat peeled right off during the test. I am going to attempt again after cleaning.
I used acetone to clean but perhaps just soap and water?
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Mon Aug 10, 2020 10:33 am
My '73 and 74 both have MDPE which takes a very special cement.
Oil impregnated crack interface will not bond well.
If I were me!!??? I would try a spot heat gun or iron, to chase the crack closed.
cliff
3M Scotch-Weld Plastic & Rubber Instant Adhesive PR40, Clear
all of these glues need surface deactivation via. flame/ ozone/ or special activator.
Probably not very strong on butt joints esp. with oil weighing on the sides and hitting bumps...
Wonder how it split?
PostPosted: Mon Aug 10, 2020 5:38 pm
The plaque plastic wouldn't be ABS, it would be PVC.
