Thanks!
a. Secret Sauces (e.g ATF/Acetone) and heat followed good beating in places that leave no marks. sounds like my childhood
I looked at YouTube for best rust removers.... I also think those modern liquid like Evapo Rust or Metal Rescue may work.... but oil soaked may block it now. Has to be more rust than Al oxide
b. Thread holes and use bolts as puller (not sure why that's harder, don't see how it really ruins cylinder either as TomTips states ?). I would do all 4 holes. Funny to see at the bottom of threading holes article it has "Flash Tap Out ... rust remover ...does it work... secret sauce back then..
c. The third method is a fabricated puller mechanism with prongs protruding into Ex and Intake and air hammer down studs.... Wow!
I was thinking if I had a long thin pick with a thin handle keep circling around stud remove crud a bit at a time between cyl. There is a gap there albeit plugged. I have a long stiff wire but need three hands and better eyes and too thin up top to apply side way torque. Stab only... working but slow.
Well I will take my time with special sauces and then may shift to threading the hole.
The hole is 13mm I think. I measure 0.509". this just about correct for 9/16-18 tap... thin thread depth may strip easy?
The article says 5/8- but not sure if fine or coarse thread. It looks coarse. Different recommend drill size NC vs NF.
The other youtuber I Posted used 16mm 2.00 mm.
some numbers
9/16 -18 NF Tap, make hole 33/64" = 0.516" = 0.023" thread depth.
5/8 - 11 NC Tap, make hole 17/32" = 0.531" = 0.047" thread depth.
16mm 2.00 mm coarse Tap, make hole 14.2mm~35/64 = 0.547" = 0.041" thread depth.
16mm x 1.5mm Tap, make hole 14.7mm = 0.578" = 0.026" thread depth.
5/8 - 18 NF Tap, make hole 37/64" = 0.578" = 0.024" thread depth.
It just aluminum so either would work even if it has to drill a little extra as it threads, accept maybe the 5/8-18 or 16mm x 1.5mm
NC vs NF ~ twice thread depth
But fine has more area to spread torque... hmm
https://resources.tannerbolt.com/articl ... 0materials.
Thinking coarse for a puller...less force maybe, but more durable with use
Need something else to think about
