It is currently Tue May 06, 2025 5:10 pm
 Post subject: hard starting H1
PostPosted: Fri Oct 28, 2011 12:19 pm
Hi
Why is it so hard to get these bike to start up after a rebuild :thumbdown: :thumbdown: :e4 . 1974 H1 500
i had to split the cases to find the small nut that is part of the nutraul switch it droped in the tranny.
after i found it i sent out my crank to charile smith for a rebuild he dose nice work.
I have all the ingredients that is needed for it to run. grate spark, fuel and good comp,timing
i have kicked this bike over a 100 times and it wants to fire but it wont.
one thing that i notice is when it all most starts it kick backs like it has to much compresson i dont have a gauge to check it.
my leg is ready to fall off :banghead will some one make a electric start . like the 2010 KTM 250 2stroke :thumbup: :thumbup:
Thanks
Chris
 Post subject: Re: hard starting H1
PostPosted: Fri Oct 28, 2011 12:26 pm
are the coils firing on proper cyl ??
downwind of three mile island
PostPosted: Fri Oct 28, 2011 12:29 pm
The usual "culprit" is crossed plug wires. They may not look crossed but the wiring to the coils could be incorrect. Trace this very carefully just to eliminate that possibility. .... are those lab seals? (I know they are, just kidding as the proponents of rubber seals state that lab seal cranks make for harder starting).
PostPosted: Fri Oct 28, 2011 1:11 pm
I would guess it's crossed wires. And it's a wives tale about lab seals, they will start just as easy as rubber seals.........
PostPosted: Fri Oct 28, 2011 1:17 pm
Hi
when i pulled the motor all i did was take the plug wires off the plugs rebuild the motor and put it back in 150 kicks later still wont start what i hunk of S**t.( if this is try lab seal cranks make for harder starting) i am a believer of that
PostPosted: Fri Oct 28, 2011 1:31 pm
Something got changed somehow. A freshly rebuilt engine isn't any harder to start than one that's been sitting for a few days, and won't take more than 3-4 kicks unless something is wrong. Make sure the engine is well grounded to the frame. Maybe there was a ground wire you didn't replace?
You had to disconnect the wires between your alternator and the ignition system when you removed the engine. Mixing up two of the wires between the alternator and the coils would result in these symptoms.
I'm assuming you have the late H1 CDI ignition system, which as one small box and one larger box, mounted on a plate, and uses a sort of distributor that's built in the alternator to choose what plug to fire.
PostPosted: Fri Oct 28, 2011 1:36 pm
maybe a stupid question...was it running before you tore it down ?
PostPosted: Fri Oct 28, 2011 1:58 pm
72zx7r wrote:
Hi
A backfire is a huge indication of crossed wires. Did you unplug the stator and remove it with the motor, or left in on the frame? And every RD in the world, snow mobile , jetski/watercraft would be hard to start, as they have lab seals. I run them exclusively, and when tuned properly, 1 or 2 kicks for the last decade. The guys that blame lab seals, have no understanding of how they work.
PostPosted: Fri Oct 28, 2011 2:17 pm
Well, I understand that there have been a few made with way too much clearance, leading to hard starting and low power. That's not the problem here though.
PostPosted: Fri Oct 28, 2011 8:47 pm
72zx7r wrote:
Hi
I understand exactly how they work. RD's watercraft, and snowmobiles were designed with lab seals in mind. The triples were not. Look at an RD seal. It is 1.5" wide. The narrow seal on the H2 is about 3/8ths" wide. Put 2 identical H2s next to each other (one with labs and one with rubber seals) rev them a bit from idle and I will pick out the bike with labs every time.
