It is currently Mon Jul 14, 2025 12:17 pm
PostPosted: Fri May 05, 2017 5:14 pm
Hi guys and gals-
Anyone can point me in the right direction to get a "all in one kit" to include all engine gaskets, seals, carb rebuild parts? Does such a kit exist or do I have to get everything separately? 1972 h1b.
Thanks in advance. :thumbup:
PostPosted: Fri May 05, 2017 5:38 pm
Gaskets and seal kits are usually separate. No carb kits out there are worth a crap, and are also separate. there are a couple of places you can get the gasket and seal kits midatlanticcycle.com, Jessbikes.com, Diablocycle.com are all top suppliers.
PostPosted: Sat May 06, 2017 6:47 am
If you are using the seals from the kit for the inner crank seals, I suggest making sure they are the K&S brand. This is the brand Sudco supplies. Good seals. :thumbup:
PostPosted: Sat May 06, 2017 10:06 am
no kits come with the small check valve gaskets at the bottom of the 74/75 engines.
PostPosted: Sun May 07, 2017 3:41 pm
Correct, I bought mine at Fast by Gast.
PostPosted: Mon May 08, 2017 10:50 am
....No carb kits out there are worth a crap, and are also separate.
Good to know :lol: What tends to be the problem with the carb kits?
PostPosted: Mon May 08, 2017 11:05 am
Mainly that the jets are not the same size (flow) as the stock ones. Some guys buy the kits to use the bowl gaskets and float valves and throw the rest away.
It's rare when you can't carefully clean the original jets with some carb cleaner or lacquer thinner and copper wire. If you do need new jets, you can get genuine ones from a Sudco dealer. Mid Atlantic Cycle has been my source. The needles and needle jets are the exception. I'm not aware of stock replacements being available.
Ivan's carb kits are reported to work well, and fix some things about stock jetting. His kits have a lot of parts, including proprietary needles and jets, so they're not cheap.
PostPosted: Mon May 08, 2017 11:09 am
...The needles and needle jets are the exception. I'm not aware of stock replacements being available.
I'll have to dig out my carbs and look at what the stockers are...is it worthwhile looking into making these? I've had some success with other bikes making needles before...of course those were honda four strokes :lol:
PostPosted: Mon May 08, 2017 11:10 am
Is there some reason you think you need new needles and needle jets?
PostPosted: Mon May 08, 2017 11:35 am
I might not but others may? Would be neat to try and archive the data and give it a whirl as time seems to only make things more and more scarce for these bikes!
