It is currently Tue Apr 16, 2024 5:48 pm
 Post subject: TM34 Jetting
PostPosted: Wed Apr 19, 2017 8:24 pm
I picked up a set of TM34's that were attached to another H2. Last night I took them apart and noted the jets.
Here's what my carbs have:
Main 250
Pilot 55
Needle Jet 389-06 OR 389-Q6 (I couldn't tell for sure)
Needle 6FP55
The needle doesn't jibe with any of the other TM34 setups in this table: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
I'm wondering if I should just buy new jets rather than try and work with what I have. The seller described the acceleration as "brutal" and that might be good or bad.
If anyone has jetting for TM34's not shown in the table or any other suggestions, please share.
Thank you
 Post subject: Re: TM34 Jetting
PostPosted: Thu Apr 20, 2017 5:38 am
I'd try them first. NJ is a Q6. Three seem rich which is good. Don't know about the needle. It's not listed in the Sudco catalog. Sure that number is correct?
PostPosted: Fri Apr 21, 2017 2:11 am
I checked all the needles and they are all marked 6FP55. I wonder if they are Factory Pro needles?
PostPosted: Fri Apr 21, 2017 4:50 am
It is a valid Mikuni number:
Mark Slots LtotL0 D1 D2 K1 K2 K3 K4 K5 K6 A1 A2 A3 A4 A5 A6
6FP55 5 63.700 2.600 2.522 0.000 30.900 42.400 0.000 0.000 0.000 0.000 1.30 4.00 0.00 0.00 0.00 0.00
PostPosted: Fri Apr 21, 2017 10:53 am
Currently running O-0 needle jet, 6DH2 4th clip, 190 main, 42.5 pilot
PostPosted: Fri Apr 21, 2017 3:40 pm
Thanks Dale and Soflah!
PostPosted: Fri Apr 21, 2017 10:00 pm
That is super rich most likely
PostPosted: Sat Apr 22, 2017 4:46 pm
I ordered 240 and 230 mains. Then I'll try the carbs out and see if the jet needles / needles will work with the H2.
PostPosted: Wed Apr 26, 2017 4:36 pm
Hello Mike,
I just put TM34's on my H2 this year as part of the resto project.
Pilot 45
Main 240
Slide 4.0
Needle 6FJ6 - 2
Needle Jet 389 Q6
It's rich down low, hits hard @ 5000/5500
Today I went down to a 42.5 pilot and dropped the needle to the 3rd position.
The motor is ported and John did the heads and cleaned up my port work. He can probably explain what he did better than me.
Once I get a chance to ride it I'll post the Butt Dyno results.
Craig
PostPosted: Wed Apr 26, 2017 8:04 pm
Hi Craig,
Thanks for the info. My main jets are in the mail and sometime after they arrive I'll put these carbs on and see what happens.
Mike
Users browsing this forum: Tim Steele
