It is currently Sat Jul 12, 2025 11:15 pm
PostPosted: Sun Mar 19, 2017 2:08 pm
Hi all, I've done numerous searches and have found many threads talking about the o ring replacement, but can't find any talking specifically about the counter shaft seal replacement. I replaced the o ring and torqued the sprocket properly, but it's still leaking a ton of oil. Can any one advise? Can I do this without splitting the cases?
Thanks in advance for any help.
PostPosted: Sun Mar 19, 2017 2:59 pm
Counter shaft seal is pretty easy to do when the sprocket and sleeve that slides on the transmission shaft are removed. Maybe Moo has a video, I'm searching you tube and not finding it at the moment.
PostPosted: Sun Mar 19, 2017 5:17 pm
No video, they pull out real easy when the sleeve is off. Just be careful when installing the new seal. And you are sure it is coming from behind the sprocket?
PostPosted: Sun Mar 19, 2017 6:56 pm
Doesn't the "book" tell you to put the O-ring in the wrong place, which causes leaks....can't remember off-hand..? :think:
PostPosted: Sun Mar 19, 2017 7:35 pm
Thanks for the responses guys. I'm pretty certain it's coming from the sprocket. I first thought it was a shifter seal and replaced that, but still leaked. When I tried pulling on the sleeve, it was pretty stuck. I replaced the o ring and haven't gone back in to mess with it. I didn't want to chance screwing up the sleeve, so I didn't force it. Is there anything special or tricks to pulling it?
Thanks again
PostPosted: Sun Mar 19, 2017 8:00 pm
The 22 mm oring goes behind the collar/ sleeve
So in other words yes the manual is wrong and oring
Goes between transmission bearing and collar
The collar has a bevel too
Collar seal is replaced easily with collar out
Look closely for possible leak near clutch push rod as well
http://davestriples.com/
PostPosted: Mon Mar 20, 2017 6:06 am
Thanks. To confirm that is where I placed the o ring. I saw in another thread that the manual was wrong. Any tricks with the sleeve, or just grab it with channel locks and pull? I just didn't want to screw it up.
Thanks again for the help.
PostPosted: Mon Mar 20, 2017 6:29 am
The sleeve should pull out by hand...you can coax it gently with channel-locks, but don't scratch it .
PostPosted: Mon Mar 20, 2017 6:39 am
http://www.kawatriple.com/manuals/maint ... .htm#trans
PostPosted: Sun Mar 26, 2017 9:23 am
Man, I don't know what's wrong, but this sleeve won't budge with vice grips or channel locks. Any ideas? Could the seal be replaced with the sleeve in place?
