It is currently Thu Oct 31, 2024 6:46 pm
Post new topic Reply to topic  [ 207 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 21  Next
PostPosted: Tue Feb 28, 2017 5:38 pm
Did you remove the pilot jet and clean it?
Did you run a wire thru all passages?
Just spraying some carb cleaner in it won't do much.
http://kawatriple.com/carb/carbclean.htm
PostPosted: Wed Mar 01, 2017 1:43 pm
Yes I removed the pilot jet and cleaned, couldn't see any obvious blockage in the passages.
It was some dirt in the channel to the air screw that I got rid of (I think).
The fuel inlet pipes to the middle and right carburetors are loose, could false air be drawn in from there? Is possible to fix them?
The carbs are not synced, middle throttle lifts way before the other two.
PostPosted: Wed Mar 01, 2017 2:57 pm
Then the first thing to do is set the idle screws even and then sync the cables.
PostPosted: Fri Mar 03, 2017 11:32 am
New float needle sets are on their way. That should make the carbs stop dripping gas at least. Float heights looks correct.
I have looked into the other carbs now and the houses and bowls look like new. The parts made of brass while nice overall show signs of being exposed to old gas (I suppose). One float is partially black. :wtf:
Ultrasonic cleaning maybe is worth trying to get more crap out?
PostPosted: Fri Mar 03, 2017 11:43 am
Just switch carb between cylinders and see what happens?
PostPosted: Fri Mar 03, 2017 11:57 am
I suggested that in the first reply in this thread.
PostPosted: Fri Mar 03, 2017 12:26 pm
Yes it's easy to try, will do that tomorrow.
PostPosted: Fri Mar 03, 2017 2:09 pm
I got an idea, just switch carb between cylinders and see what happens. :shock:
PostPosted: Fri Mar 03, 2017 2:12 pm
Damn Jay, just when we run out of ideas, a good one comes along!
PostPosted: Fri Mar 03, 2017 3:43 pm
Perhaps move the other cylinders around :lol:
