I'm moving this thread from the previous post (from restoration shiny and new section ) the bike is crusty, doesn't belong in that category
It was 65 and sunny today in NW Indiana, so today was the maiden voyage on the 74 barn find. First time with gasoline in the tank instead of premix. Bike ran great nice mid range no problems except..............
1. Idle too high how do I adjust three carbs
http://www.kawatriple.com/manuals/carbt ... ne.htm#adj idle 2. Bike will not shut off with key , I have to use the handlebar switch ? how do I fix that
The blk/wht wire from CDI to ign sw should connect to the blk/yel via ign sw in "off" position... that kills the engine like kill sw does. Make sure those wires are connected solid in the connector block.
http://kawatriple.com/wiring/H2Bwir.JPG 3. I rebuilt the petcock but it leaks ?
Depends on where it is leaking
ok can't load photo because this sight is out of date
Site "out of date" has nothing to do with not being able to load a photo.
