It is currently Mon Jul 07, 2025 6:26 am
 Post subject: Max Rear Tire Size
PostPosted: Mon Feb 13, 2017 7:12 pm
What's the maximum rear tire size available that's been able to be fitted to a stock H2B swingarm?
Mike
________________________
2006 Honda Goldwing
1995 Yamaha Vmax VMX12G
1986 Kawasaki KDX200
1974 Kawasaki H2 750
 Post subject: Re: Max Rear Tire Size
PostPosted: Mon Feb 13, 2017 7:40 pm
It really depends on the brand. Usually a 130 is the widest, but you get tread rollover and traction suffers with the stock rim width.
PostPosted: Mon Feb 13, 2017 7:59 pm
Yeah, I have a 130 on a 3" Lester and it barely fits if you don't mind it just touching the chain guard and brake stay. It's pretty close to the swing arm, so I'm not sure a 140 would clear that. My goal was not to go really wide, just get the tire size that Bridgestone recommends for a 3" rim.
PostPosted: Mon Feb 13, 2017 11:33 pm
Yes, I have a 130/80-18 tire on a 3.5" rim. There is sufficient clearance at the swing arm, but I mounted the front of the rear brake torque arm further out, 12mm or so, and shaved the inside of the stock chain guard just a little.
PostPosted: Tue Feb 14, 2017 4:33 am
120 is more comfortable than 130 which is very closed from everything (chain guard and brake bracket) but I prefer 110 8-)
PostPosted: Tue Feb 14, 2017 9:53 am
A Avon Roadrider 130/70 works very well.
76 KH500, 06 KLX 250S, 03 Suzuki Burgman 650, H1 roadrace, A1 roadrace, 91 KX250, 81 Ke175, etc
PostPosted: Tue Feb 14, 2017 10:07 am
Avon Roadriders just work very well in general. :)
PostPosted: Tue Feb 14, 2017 4:30 pm
Rim size range for this tire is 3.00 to 4.00
Recommended size is 3.50
PostPosted: Fri Feb 17, 2017 12:06 am
That is what I use on my KH500 and it does not wrap as much as some 110 or 120 tires. The chicken strips are very narrow without touching the stock pipes. Avon does make a 130/65-18 roadrace tire that is made for a 2.18 rim.
PostPosted: Sun Apr 02, 2017 1:47 pm
So my neighbor offered me an Avon AV71 Cobra 130/70R-18. It only has 150 miles on it but it is 5yrs old. You guys think this will clear? I really don't want to modify anything. And I'd hate to pay for mounting just to find out it doesn't fit and have to have old tire put back on.
Also this tire is a radial and my front is a Bridgestone Battleax BT45 100/90-19 Bias ply. Is it still taboo to mix radials and bias plies?
Mike
2006 Honda Goldwing
