It is currently Tue Jul 08, 2025 7:40 pm
 Post subject: Stripped thread
PostPosted: Sat Oct 01, 2011 6:06 pm
Threads that are built in frame for my left side cover are stripped out. Any ideas to fix. I will have to look real close maybe theres enough in there to tap out to larger size. Using original knob type fastener not a big issue
thanks in advance
gregz
1973 Z1
1974 H2 750
1976 kz 1075cc ATP turbo
 Post subject: Re: Stripped thread
PostPosted: Sat Oct 01, 2011 6:16 pm
Heli coils work fine. :)
PostPosted: Sat Oct 01, 2011 6:17 pm
That's one way to fix it. I drilled out my left side cover's frame thread and re-tapped it to 1/4-20 about 32 years ago and it's still holding. I make the bolt good and tight, too.
PostPosted: Sun Oct 02, 2011 10:40 am
You could use a longer bolt with a "nyloc" nut on the back of the bracket so it isn't overtightened (to break the covers tab off) nor come loose??
PostPosted: Fri Oct 07, 2011 1:46 pm
Correction: I just had my left cover off, and I used a 5/16-18, not a 1/4-20 bolt.
PostPosted: Fri Oct 07, 2011 4:38 pm
I don't know what size the screw is, I went to Ace Hardware, found some suitable knobs and tapped the frame for them - worked great!
