H2RTuner wrote:
If you have to go inside the engine, please be aware there are differences between the F and K models in the top end parts, heads, cams, and, even differences between different year F models. Early F had a basically K-like head and cam setup in lobe centers and valve angles, later ones, different, larger valve'd head, different valve angles, piston domes, and completely different camshaft basics, and that stuff DOESN'T interchange.
Those bikes are the best of the early "single cammer" Honda 750's, I feel. The later ones are fairly fast, and run really great when tuned correctly.
Thanks for the info, the plan is to rebore, rebuild the heads, and hopefully with only 13000, the lower end will be looking good. I have already got the 750f valves, but the pistons don't seem to be as available. The info I have gotten over on the SOHC forum is the K pistons will give a slightly lower CR but will work fine. One thing I have learned is that the "F" is not restored anywhere near as much as the "K" model. You can buy much more repro products for K bikes than the F. No problem, I'm up for it and don't mind a challenge.
