It is currently Tue May 06, 2025 6:20 am
PostPosted: Wed Sep 09, 2015 4:42 pm
Hey Guys,
Looking for some help to get this oil pipe.16134-006
Have been looking for months but no cigar.
The engine side brass junction is slightly higher than the
later ones, which also uses a different
banjo-bolt.I don't mind a good used one.Thanks
PostPosted: Thu Sep 24, 2015 10:30 pm
Just bumping it up there.I know they're are not that common.Can you guys with early H1's ones afford to part with a spare.
Have cash or some h1/h2 parts to swap.
Here's a pic from Mraxls' resources :arrow: http://3cyl.com/mraxl/partid/oillines/oillines.htm
PostPosted: Fri Sep 25, 2015 12:18 am
What does the wider brass fitting measure, Tone, I have a set of '70 cases with a few oil lines, and fittings....... may not be 'early' enough???
PostPosted: Fri Sep 25, 2015 12:23 am
...just had a look, I think the fittings I have are 'later' ......
PostPosted: Fri Sep 25, 2015 1:15 am
Hey thanks for looking Rod,the brass fitting is 12mm as opposed to the later ones,I think 7mm.
The early ones take a different banjo bolt, 92001-061.
I don't think there is a bulletin about it and only RB would probably know when they changed it and who? :P
Maybe Tuner knows why.
Thanks again Rod,tone :thumbup:
PostPosted: Sun Sep 27, 2015 1:25 pm
Tone, good to see you're still at it! Hope all is well. :thumbup:
Please compare to yours to be sure this one is correct. If so, $25 plus shipping. I believe Priority Flat-Rate to you is $12.95, but let me actually put the particulars into the USPS online before I total it up, as I am not 100% on that and the USPS seems to raise int'l prices frequently. Let me know if you want it.
PostPosted: Sun Sep 27, 2015 4:17 pm
Hey Darrin,
Yes still at,I have had a few family issues.... :( but looking at getting some projects on the bench.
That is the oil pipe pictured Darrin and thanks for looking into it for me.I'll pm my pay p@l address.
Tone :wave:
PostPosted: Sun Sep 27, 2015 4:39 pm
I would wait and try to find one without the air bubble, that's gonna cause you problems... :think:
:lol: :e11
PostPosted: Sun Sep 27, 2015 9:07 pm
You're a regular Jerry Seinfeld! :P
PostPosted: Mon Sep 28, 2015 6:32 am
...not that there's anything wrong with that! :mrgreen: :wave:
