Darth, thanks for the offer, but Moo beat us both to it.
Those be the pistons, and they are no thicker in the skirts than an ART for an H1 or H2. I have even opened the cuts up to the center of the wrist pin diameter area, with NO adverse affects. The picture is deceiving, as you see a cross section of metal, instead of straight on the cut. I've used these things, and a lot of other pistons cut like these, and more radical, in all sorts of two stroke reed valve engines, and not had one problem with any of them. Look at the bottom of the skirt on the exhaust side, and you will see that the piston thickness isn't larger than conventional "full skirt" pistons.
The first ones of these I saw were on Roberts', Baker's and Cecotto's factory race engines at Daytona, before the OW31 Replicas were available, machine milled into the regular full skirt pistons. The piston in the picture is a factory replacement one, from later stock, made/cast just the way it looks.
These were done on Yamaha engines because Yamaha engineers knew that the intake skirt simply became an obstruction to the port and mixture transfer when it was either left long, and/or drilled/slotted, so they designed this cut. This let the reed dictate the inlet operation, NOT the piston skirt, and was used along with a port at the top of the inlet port, that aimed mixture up to the spark plug. That added port was literally an added transfer port then, as the inlet port remained open to the bottom end at all times. All the reed valve TZ750 cylinders, and especially the best factory TZ750 cylinders, both factory and privateer, has one of these ports at their inlet side, off the inlet port. Privateer cylinders had 2 transfer ports per side, making them "5 port", and the factory team cylinders had this port, and 3 transfers per side, making them "7 port" cylinders.
On the cylinders I did for Harry Klinzmann's, and others TZ750's and other cylinder reed valved engines, I also added the finger port type that was above the intake port, to the bottom of it as well. The inlet port then became a boundary layer area when the reed closed and the piston came down, making both cuts into their own full transfer port, with no piston materials in the way to obstruct transfer port mix movement up the back of the cylinder. Imagine hour hand standing straight up. factory piston port cut would be the palm of your hand. Added upper port would be the two center fingers, standing curved, upright. Now, imagine another set of two fingers, going down from the bottom of the inlet port, into the crankcase, that is the extra port into the cylinder I cut. When the inlet port is closed off by the reed, mixture is pressured up the bottom added port, through the inlet port as a guided flow, through the upper port, to the cylinder and spark plug. Added transfer port, no obstructions, works well.
As I said, if the skirt isn't there in the first place, it can't break off.
