Nothing too fancy, just stuff left over from when I had an S3 and was thinking about putting H1 carbs on it...
--Two sets of H1 carbs. EDIT--BOTH SETS OF CARBS ARE SOLD They are later types, not the ones with the idle adjustment "rod" sticking straight beside the throttle cable. One set looks rebuildable, other set probably only good for parts. The "better" set has the chrome plated slides, and they are not stuck. the "worse" set has the brass slides and IIRC, they are stuck. There is goop in the bowls, of course, but not 1" thick like some I've seen. the "worse" set has cables still attached. Edited to add: The "better" set appears to actually be a set of 73 Suzuki GT750 carbs... --H1 kick start lever. Looks decent, missing the rubber.
--H1D rider's handbook--pretty decent shape. SOLD --One S2 center cylinder. I believe it is on original bore, but it has some scuffing and will need honed (at least, maybe bored)
--KH400 ignition (stator, no CDI boxes) SOLDF.
EDITED 03/27--Everything gone except for S2 cylinder. Please give it a home!
Probably a few other odds-and-ends.
If somebody made me a decent offer for the whole mess, he'd take it.
My email is orionengnr at yahoo dot com
