It is currently Wed May 07, 2025 4:42 pm
PostPosted: Thu Jun 27, 2013 11:37 am
The crank seals wore out and I took off the engine. It would be good for transmission parts, clutch, carbs, covers.,.. The cylinders are probably worn stock bore. I also have a head that is milled 20 thousandths. ..Dirt cheap...,You might want to message me to get my attention.
EDIT. crank will be gone. I took the transmission out sprayed it with oil and put it up. The shift forks look good. Besides that i have an oil pump and good lines, clutch basket is wore out, some covers. All the ignition parts are good....the rest went under in the flood and is probably no good.
