It is currently Fri May 02, 2025 9:50 am
PostPosted: Fri May 22, 2015 9:02 pm
I have a few sets of these emulator adapters for sale. These are for h1/h2 forks with steel damper rods and are made to work with the Mikes XS clone adapters which are much cheaper than the race tech emulators. They can be seen here https://www.mikesxs.net/product/27-1086.html Whats included is 2 adapters that have an anodized finish in them, 4 dog point set screws, and a tap for the set screws. These replace the stock damping rod end. You will have to drill and tap the adapters to mount them. You can either match the holes to the stock roll pin holes in the rod or drill a complete new hole through the adapter and damper rod. The price is $37.50 shipped in the USA(add 3% if paypal is not a gift). Here are some pictures of the adapters and what the look like mounted on the rod with the gold valves. I can also do a complete damper rod mod with mounted adapters, see here. viewtopic.php?f=25&t=10247
PostPosted: Sat May 23, 2015 1:58 am
PP sent
