It is currently Sun May 11, 2025 3:47 am
 Post subject: A1/A7 Crank Core
PostPosted: Fri Dec 13, 2013 8:47 pm
I need a A1 or A7 crank core. I really just need good flywheels, not worried about the rods or bearings. The crank is going to be stripped and stroked to run Yamaha rods for a race bike.
Thanks Dave
 Post subject: Re: A1/A7 Crank Core
PostPosted: Sat Dec 21, 2013 12:28 am
What bike, your A1R?
76 KH500, 06 KLX 250S, 03 Suzuki Burgman 650, H1 roadrace, A1 roadrace, 91 KX250, 81 Ke175, etc
PostPosted: Sun Dec 22, 2013 10:48 am
H1 or Jetski JS440 rods are dimensionally identical to A1/A7 rods apart from the centre-to-centre length and require only a new crankpin to be made if you don't have new A1 or A7 crankpins- no machining of the flywheels if you retain the stock 56 mm stroke. You gain some crankcase volume, which is beneficial for disc-valve engines, but do have to make spacer plates and fit longer cylinder studs, 172G0870 instead of the stocker's 172G0865.
I think I have a spare set of A1-R flywheels, mail me if interested.
