It is currently Mon Jun 16, 2025 2:14 pm
 Post subject: H2C Frame Wanted ('75)
PostPosted: Tue Jun 21, 2011 6:37 pm
Looking for a H2C frame for another project bike. I have a complete engine, but need to find a frame...
PostPosted: Tue Jun 21, 2011 9:22 pm
What serial number engine?
PostPosted: Wed Jun 22, 2011 3:49 pm
The engine is from an H2B, part number H2E-37720
However, I would like to build an H2C, starting with the correct frame, if possible.
PostPosted: Thu Jun 23, 2011 3:03 am
Fellas, correct me if I'm wrong, but the only major difference between the two is cosmetic - the tank and seat combo - otherwise I believe the frame/swinger, etc. is the same, save for a few minor details like 0mph increment speedo, side cover emblems with white inlay, and of course the decal/paint scheme.
PostPosted: Thu Jun 23, 2011 3:42 am
real H2B frame hasn't the brackets welding on the frame to fit on the rear the H2C tank rubber but only those for H2B tank rubber which are fitting shorter on the frame as the H2B tank is shorter than H2C tank.
And early H2B frames have the hydraulic steering bracket on the frame on the right not on the left. :mrgreen:but engine 37*** should have the hydraulic steering bracket on the left as mine which has low numbering than this engine has already the bracket on the left :mrgreen:
PostPosted: Thu Jun 23, 2011 2:01 pm
Merci for clarifying JP! :thumbup:
PostPosted: Fri Jul 08, 2011 10:13 am
I have some left over parts, 75 H2F 47038 frame, the only thing I see wrong is someone welded another set of rear shock bolts on it, also have the swingarm, iner rear fender. its on craigslist albany,ny also.
PostPosted: Fri Jul 08, 2011 1:20 pm
The mounting point on the frame for the rear brake light switch is a different design on the B and C :o
Theres one for the anoracks :D
PostPosted: Fri Jul 08, 2011 2:47 pm
I know of one you could get, if only you had put your location in your profile....
:P :P :P
