It is currently Mon Apr 29, 2024 6:13 am
 Post subject: NEED 1975 H2 TANK
PostPosted: Wed Apr 11, 2012 11:53 pm
well since i got ripped off by a board member for my body set i need atleast a tank for a 75 h2 , i may have the tail and side covers from a 74 which i believe are the same but i know the tank isnt , i would really like a whole painted body set but just let me know what you have , thanks.
 Post subject: Re: NEED 1975 H2 TANK
PostPosted: Thu Apr 12, 2012 2:07 am
you need a 75 seat too, specific for 75 H2C :mrgreen:
PostPosted: Thu Apr 12, 2012 8:02 am
I,m putting one up on evil bay shortly. Faded original purple paint. Rust free inside but has a Large dent in it. Body shop should be able to get it out easy enough though.
PostPosted: Thu Apr 12, 2012 8:54 am
I wouldn't classify the guy that ripped you off "a board member". From all I could see from his posts, the guy was here solely to peddle his wares.
which if I recall correctly included....
Spraypainted (I believe his term was "replated") Iggy Boxes :roll:
and from what I witnessed, poorly executed resprays with grossly inaccurate colors and shoddy decal placement.
Believe me, nobody hates getting getting ripped off worse than I do, and it SUCKS that you have lost the bodywork, but at least now you'll have something that is closer to "CORRECT" as Im pretty sure the work you received would have been sub-par anyways.
PostPosted: Thu Apr 12, 2012 9:57 am
Or, if you don't mind, you could also use a 74 H2B seat/tank combo which generally should be cheaper to purchase than the equivalent H2C parts... :think:
PostPosted: Thu Apr 12, 2012 12:16 pm
But then it would be a lot uglier than an H2C :P
PostPosted: Fri Apr 13, 2012 11:10 am
Be glad to send you some pics of the 74 body set and seat I was going to trade for the Tracy. Dent and filler free.
PO painted the parts all lime green and they do need a stripping and repainting.
The seat is a beauty that had nominal wear and rust and then our very own "Assman" H2Brad worked his magic on it with a new RB cover and I believe foam too.
No tin strips is the only flaw. All new rubber blocks etc.
Like I told the last guy, I have fair appraisels of it all and will not let it go cheaply.
Need money for air fare to Belgium man.... :mrgreen: :mrgreen: :mrgreen:
