It is currently Thu May 01, 2025 6:16 am
 Post subject: MORE leak issues!!
PostPosted: Mon Jan 30, 2012 12:10 pm
Gentlemen, Ive systematicaly replaced most of the 40 year old rubber on my 72 H2. Now my shifter shaft seal is the last to do, and it IS leaking. Anyone know the part number? Ive got nothing. None are selling on Ebay as "shifter shaft seals".
 Post subject: Re: MORE leak issues!!
PostPosted: Mon Jan 30, 2012 12:13 pm
I personally just get a seal kit. Eventually you will use them, and they will be right there.......
Plus, most triple side stand mount bend and the bike leans way far over, and the seal leaks. If you haven't already, stick a 2x4 under it and see if the leak stops.
PostPosted: Mon Jan 30, 2012 1:17 pm
92049-004
http://www.ebay.com/itm/KAWASAKI-92049- ... 351wt_1398
PostPosted: Mon Jan 30, 2012 1:57 pm
Are you sure its the same? its a part for rotary valve singles. The price looks good.
PostPosted: Mon Jan 30, 2012 2:20 pm
PostPosted: Mon Jan 30, 2012 2:21 pm
RepoDecals has them single for $7.50 plus shipping or just get a whole kit for 30 bucks.
http://www.reproductiondecals.com/defau ... .html~main
Kawasaki H2, Z1, KZ
Seal - Shift Shaft
H2, H1, KH500, Z1, KZ900, S1, KH250, S2, S3, KH400, and possibly other models.
Genuine Kawasaki part. SB12205
bb
PostPosted: Mon Jan 30, 2012 2:28 pm
http://www.ydsparts.com/H2.htm
http://www.ronayers.com/ProductDetails/N/687/SKU/1087122
Like reprodecals, this seller is a member here, as well as on ebay - :mrgreen: http://jessbikes.com/product_info.php?products_id=63 :mrgreen:
PostPosted: Mon Jan 30, 2012 2:58 pm
Kawi used the same seal for a bunch of motors
PostPosted: Mon Jan 30, 2012 5:26 pm
Just as point of info on some seal numbers.
Some seals, like the one identified above, have a dedicated part number, and, some have one that is only numbers. In the case of the seal above, 12205, we can break this seal size down by that number. 12 would be 12mm's, inner (shaft) diameter, 20 would be 20mm's, overall (housing) diameter, 5 would be 5mm's, the thickness of the seal. This same number system, or a reasonable version, should also be embossed on the seal itself, so ident can be done.
If there is a specialty OEM part number, then, the seal may be either a specific size for that application, and/or have differences in the seal configuration, etc.
Applying this seal as an example, it has the 12 x 20 x 5 dimension, and a positive spring assisted inner seal lip, with ambient pressure (no spring) outer dust lip. This might help to be able to find a different seal from a different manufacturer, that would interchange into one of our applications.
Just FYI for all to consider.
