It is currently Fri May 10, 2024 1:32 pm
 Post subject: Jug stud bolt
PostPosted: Wed Dec 16, 2020 4:28 pm
Hi guys,
Looking for a cylinder stud bolt. This one, on the center upper right, just doesn't look & sound right!
I had a difficult time getting the right [cut out of this pic] jug off-- much banging and heating with more banging, so I probably damaged it..
This is a link to a VIDEO-- you can hear the difference in pitch!
((I couldn't figure out how to embed the video in this post, so the link will take you out to flickr.)) :wave:
I might be over paranoid, but I'd rather swap it now, then have it snap later! If anyone has an extra sitting around, please let me know.
MANY THANKS!
 Post subject: Re: Jug stud bolt
PostPosted: Mon Dec 21, 2020 11:21 am
so it turns out (pun intended) that the stud bolt that sounds different is because it isn't in all the way.
in this pic
You can see it is a bit mangled, so I want to replace. However, I can't get this thing to budge! what's the trick?? I don't want to break ANOTHER stud bolt!
PostPosted: Mon Dec 21, 2020 11:50 am
When heated, aluminum expands faster than the steel stud does, so that helps. Double nutting it at the end and whacking the nuts with a hammer can help break it free from corrosion. Of course penetrating oil can't hurt.
If you go to buy one, ask for a "stud", not a "stud bolt".
Diablo Cycle has sets for $110. Maybe they have a broken set for selling one or two at a time.\
This set of stainless studs with shipping is less than Diablo's set: https://www.ebay.com/itm/172G1075-KAWAS ... Sw~-ZcYDFY
PostPosted: Mon Dec 21, 2020 12:02 pm
Yeah, I have a new torch stuck in postal limbo, so once that arrives, I'll give heat a go.
Thanks Jim!
